Results 1 to 28 of 28
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    Sport Differential Troubleshooting -Temp sensor, Adaptation Reset Invalid Data Record
    Hi,
    So I picked up my 2010 B8 S4 with 131,000km on the clock. It had a code for temperature sensor in the AWD module, when I would clear it, it would go away but the second i "hucked" a corner, or aggressively accelerated out of it, it would come up with "sport differential system fault" on the dash and wouldn't clear until i cycled the ignition.
    specifics to follow:
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 HW: 8K0 907 163
    Component: 4 Wheel Drive H09 0004
    Serial number: 001905090001060
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 6DD11D90BC88172E51-8038
    1 Fault Found:
    0273 - Oil Pressure and Temperature Sensor
    C1004 F0 [008] - Oil Pressure Implausible
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 97
    Mileage: 128331 km
    Date: 2017.08.10
    Time: 23:58:27
    Voltage terminal 15: 13.91 V
    Voltage terminal 30: 13.91 V
    VPS Voltage: 13.91 V
    Pump for all-wheel drive: voltage: 0.00 V
    motor pump voltage terminal B: 5.00 V
    Pump for all-wheel drive: current: -11.25 A
    Torque distribution: 222 Nm
    Torque distribution: specified value: 370 Nm
    State KomonentenRegler: normal
    Control Module temperature: 39 °C
    Temperature output stage-Data: 35 °C
    Temperature QCU-Data: 39 °C
    Thermal load ECU-Data: 0 bar
    Thermal load of all-wheel drive pump: 0.0 %
    Oil pressure and oil temperature sensor temperature: 40 °C
    I did some reading and some chatting with a couple friends who are techs and ended up picking up an entire differential instead of buying the sensor. The sensors were expensive and the diff was actually cheaper than buying both sensors. Figured I could try the sensors at least and then swap the whole thing if they dont work....
    Here's where I know I messed up. I was in VCDS and I was just looking (messing) around in the AWD module. I went into basic settings, then was told to go into security access before I could access anything,so I did, popped back in and was in business.... There was an option to "reset all adaptation values". In my head I'm like hmm, maybe I can just reset the adaptation and the sensor will learn again or something. So I tried it. NO..... VERY NO. DO NOT DO THIS. ha. fuck.
    It seemed to reset all the adaptation values no problem. However, I don't think it automatically relearns them. At all. I think there's some sort of drive cycle required to initiate each sequence or something. I know the B6 with the G85 Steering sensor calibration makes you do circles till the lights go out. I think it requires something like that. Unfortunately there is nothing published by Bentley or Ross Tech so the only way to complete this drive sequence is through Guided Functions by a tech at the dealership? BOO.
    So now when I start the car, right away I get the Sport Diff System Fault and it warning doesn't go away.
    Most control modules that depend on it show "no signal /no comunication with AWD module" - Cluster, abs, etc.
    More specifically:
    VCID: 6D84C36D0D12193F817-8038
    1 Fault Found:
    0312 - invalid data record
    B2005 00 [001] - -
    Not Confirmed - Tested Since Memory Clear
    Has anyone else experienced this or made this same mistake. I'm not going to lie here, I'm pretty sure I fucked this up... at the same time I ask myself... why does my differential need a computer? Why did I spend money on a cable to do the opposite of what I did? Why.
    Strange as it is, I feel like the differential is still functioning when I put it in comfort or dynamic. I think I might be crazy though as I've never actually had a warning free Sport Diff since owning the car.
    Thanks in advance, any input is appreciated, Hopefully can save someone from making the same mistake at the very least.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    You will have to take it to a dealer. The regular mechanical part of the diff works, but you don't have any torque vectoring function until the computer adaptation is redone.
    Jan 13 2010
    Toronto Canada
    Quote Originally Posted by S4'ed View Post
    Thanks for trying to help. I understand this as I mentioned in my post. I'm trying to see if anyone knows the process for the adaptation. It seems silly that it's a dealership only service. I have access to all the adaptation channels in VCDS I just know there's a special sequence that needs to be carried out.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Sep 01 2017
    Broomfield CO
    Did you get thes issue resolved?
    I did the same thing. Cant find anything to do to get the sport diff warning light to go away now. Started with just an occasional implausible oil pressure.
    Anyone with any help???
    Junior Member Two Rings
    Mar 09 2014
    just curious how much was the whole differential?
    Sep 01 2017
    Broomfield CO
    I didn't replace the sport differential. I had the same issues as the OP. I did the same thing the OP did, reset the adaptation hoping the car would re-learn the adaptation. That was a serious mistake it appears. I'd copy my auto-scan from VAG COM but it looks exactly like the OP. I agree that this is silly to have to take it to the dealership to get this fixed. I just was hoping to hear from someone that might have a solution, or the dereaded trip to the dealer is the only answer.
    Sep 01 2017
    Broomfield CO
    No help so far, Ross tech tells me:
    The fault code below would need to be corrected with the factory scan
    tool (ODIS) and an online connect to the manufacture, VCDS will not be
    able to clear this fault code.
    >> B2005 00 [001] - -
    >> [Ungültiger Datensatz DTC_DAT_INVALID]
    There is a chance that ODIS may not be able to correct this concern
    and the controller would need to be replaced.
    Looks like I am off to the dealer...
    Sep 01 2017
    Broomfield CO
    Went to the dealer, 2hrs and $111 later all is working. The technician said it showed up to him as a loss of communications to the sport differential. He had to contact the manufacturer and get some information to load into the computer, don't know which computer, and once communications was established he went through the bleeding/setup process and now the car drives perfectly. Had the implausible oil pressure, before the VAG-COM reset that completely killed the sport diff, and that has not shown up so far either. No change of sensors. Verified oil levels, they where fine if not slightly high. Had 35k service before the sport diff faults started showing up.
    Happy sport differential owner again!
    Jan 13 2010
    Toronto Canada
    suppose I should update this.
    I ended up just swapping the temp / pressure sensors from my spare parts diff instead of swapping the entire thing.
    Yes the dealership can relearn the process and it should only take an hour but you do have other options. I can't go into much further detail.
    I learned that VCDS isn't the end-all be-all when it comes to audi diag. I wont say too much more but I'll leave you with a couple acronyms to look up. ODIS and ELSA.
    Cheers.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Sep 10 2012
    London
    The adaptation channels are just a deeper level of coding. There are hundreds of them and you really need to know your coding to sort them.
    A normal vcds autoscan does not show the adaptation channels that you cleared. You need to adjust the settings before auto scanning to record all the adaptation channels.
    You basically reset the fine tuning coding parameters to zero, you uncoded the module.
    Luckily not so expensive to sort. I have a full adaptation channel scan of a car with sports diff. If you do this again in the future, you have to manually reinsert the correct adaptation values one by one.
    Jan 13 2010
    Toronto Canada
    Quote Originally Posted by Adamantium View Post
    I understand what I did.
    Nice of you to offer, but the adaptation channel values will differ by vehicle - The differentials are stamped with clutch pack classification number physically on the unit. - the dealership will have to put your car on a hoist and grab those numbers and enter them in.
    heres an example of what they're looking for.
    2018-11-03_11-59-26 by ilovequattro, on Flickr
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Sep 10 2012
    London
    Quote Originally Posted by iamshayan View Post
    Did the dealership tell you that?
    I only ask because I’ve just retrofitted:
    Adaptive cruise
    Dynamic steering
    Lane assist
    Side assist
    Hill hold assist
    Main beam assist
    TV
    Passenger seat memory and a fair few more.
    I grabbed the adaptation channels from another car, and other than a few things missing that had to be worked out after fitting a new can gateway and convenience module, it’s all working perfectly with zero errors.
    I can accept that the sports diff might be the exception to this that wouldn’t have worked.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Adaptive cruise
    Dynamic steering
    Lane assist
    Side assist
    Hill hold assist
    Main beam assist
    TV
    Wow that's quite a bit of kit installed. Is there going to be a write up? Would love to peruse through it.
    Sent from my SM-N950U using Tapatalk
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Sep 10 2012
    London
    There’s was a fair chunk more than that.
    Also carplay and a fis control module, electric rear sunblind, adaptive headlights (forgot those), homelink - we don’t have that in the uk.
    I don’t have the skills for the above myself, I left it to a retrofitting friend who did the lot.
    Luckily he videoed everything. Is putting together a collection of them all that I’ll make available if interested.
    Jan 13 2010
    Toronto Canada
    Adaptive cruise
    Dynamic steering
    Lane assist
    Side assist
    Hill hold assist
    Main beam assist
    TV
    Cool, let's go off topic. here's a list of things I retrofitted myself.
    Homelink
    Autohold
    MMI 3g+ (b8.5 in B8)
    -screen upgrade
    -main hdd unit
    -control head
    -can gateway
    -climatronic unit
    -trunk mounted amplifier
    -all loom run throughout the car to the trunk.
    Keyless entry./push start
    -4 door handle sensors
    -4 antennas
    -proxomity key
    -loom
    -rs keyfob
    All the coding was done myself. The dealership had to remove component protection though.
    Getting back to my post. No that's not 'what the dealership told me.' it's what I learned through experience. The sport differential IS the exception.
    I attached one last piece of information but I'm not going any further into detail.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Sep 10 2012
    London
    Nice attitude.
    Good luck solving future issues when that’s how you treat people trying to help.
    So the sport diff is the one component where adaptation channels can’t be copied across. What were the chances?
    Such a shame you had to pay a dealer to solve your problem.
    Jan 13 2010
    Toronto Canada
    Nice attitude.
    Sorry if you don't like my attitude, wasn't trying to be rude. I'm also not looking for help - if you read the post.
    Not sure why you think I had to pay the dealer - did you not even read my posts? I gave ( what i thought were) pretty good hints as to how you could solve this issue yourself.
    Sport diff adaption channels are all based on clutch pack classification and fluid wear. You can't copy from one car to another. - it's a pretty unique system.
    Not trying to spread misinformation. Not much info is documented on these units yet. lets try to keep it classy.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Sep 10 2012
    London
    Sorry I confused you with Hughesdt. Glad you didn't lose out financially.
    On the plus side, you didn't ask for help but because I posted saying I had a full scan, someone has asked for it and managed to benefit from it - so it was useful to someone.
    Established Member Two Rings ValidatedS4's Avatar
    Oct 08 2017
    2013 S4 6MT
    Boston, MA
    I had the same error and swapped out both sensors, read and adapted them separately and still throwing the error..I guess it's off to the dealership for the sport diff service and see what they find out.
    Feb 06 2014
    portland, OR
    Quote Originally Posted by ValidatedS4 View Post
    Please report what they come up with. I’ve gone down the same path but haven’t sent my rig off to the dealer
    Jan 13 2010
    Toronto Canada
    Try changing the transfer box oil - (not the 75w90) the other stuff that's expensive and redoing teh oil aging adaption process.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Junior Member Two Rings AudiS41962's Avatar
    Nov 18 2018
    2013 Audi Allroad Prestige
    Evanston, IL
    Quote Originally Posted by nomis88 View Post
    Just had same issue on my car. Seals on both axles shot so replaced them and both sensors. Replace one and you are fine, replace the other and you are fine. Replace BOTH and you have to recode the sport differential. Mechanic has a guy who is doing this now rather than going to dealer.
    2011 Audi S4 6-speed S-Line Prestige
    Sep 24 2014
    Central NJ
    From SSP 990193:
    "Oil Pressure/Temperature Sensors G437 and G640 have
    their own serial numbers and characteristics. They are
    used to establish the identity of the sport differential for
    All Wheel Drive Control Module J492. They are colorcoded and must not be installed in the wrong positions.
    G437 and G640 should never (if possible) be replaced
    at the same time. Always replace one after the other. If
    this isn’t done, All Wheel Drive Control Module J492 will
    assume a new sport differential has been installed and
    additional adaptation and maintenance procedures will
    be necessary, including changing of the ATF.
    The speed modulation gearboxes (or super-position
    gearboxes) are tested and calibrated during the
    manufacturing process. The tolerances for each gearbox
    are inscribed on the sport differential housing in the form
    of a hexadecimal code. This code is used for adaptation
    via the VAS Scan Tool when repairs are made to the
    differential."
    Oct 13 2023
    UK
    Hi
    Just did the same to my s4 b8 avant reset all values and now get the same invalid data record fault. Any chance you still have the values would really help
    Junior Member One Ring
    May 21 2020
    Woodinville, WA
    Quote Originally Posted by WH500 View Post
    Hi
    I’m in the same boat. Surely someone has to have found a way by now.
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    Bump. Same issue after a dead battery.
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    May 21 2020
    Woodinville, WA
    Quote Originally Posted by mahhdd View Post
    If it helps you or anyone else at all I ended up having to take my S4 into a local Audi dealer, even they were stumped and gave it back to me unfixed. After a grueling 40 hours or so of research and long nights I found out about the inputting of the clutch class’s and brought it back to the dealer to have them input the 2 clutch classifications via Elsa or whatever Audi’s software system is. These clutch classification numbers are in the form of 4 characters each and located on each side of the rear differential flange (clutch one **** clutch two ****).
    I’ve tried finding out how to input these through OBDEleven and Rossteck, but to no prevail. Dealer has to do it.
    In your situation, prior to going this route I would make sure you have the 2-pin connector for the AWD control module plugged in correctly on the positive battery terminal harness. If that is connected properly I would then try to find a way to diagnose if the AWD control module itself is faulty, or if the data was wiped somehow and it just needs this clutch class programming.
    Best of luck, post back here with your findings.
    May 21 2020
    Woodinville, WA
    *battery negative connection, sorry. And check fuses as well.
