Results 1 to 40 of 40
    Nov 10 2013
    annapolis, md
    3.0 Engine Pulleys and belt Diagram images
    Hello All,
    So I've recently been having a squeaking sound under the hood in my 2011 S4. It sounds like either a squeaky pulley or belt. I've tried doing some searching online and can't really find an 3.0 T engine diagram that shows the pulleys and belts. Can anyone help me out? I just want to narrow down the squeak and know which pulley its coming from. A picture of the pulleys and belts would be very helpful.....Thank in advance!!
    2011 Deep Sea Blue S4
    7-speed DSG / B&O / MMI with Nav / Advanced Key / Carbon Atlas Inlays / Black Leather /19" Peelers/Push Button Start/Sport-Diff/Comfort Mode;)
    Modifications: Stage 2 GIAC w/Emmanuel Design Pulley, TCU DSG GIAC Tune, EuroCode Alu Kreuz, Roc Euro Intake, 034 Trans mount, Apikol mount, H&R front & rear sways
    Nov 10 2013
    annapolis, md
    I'm pretty positive it's my "idler Roller" pulley. I'm not sure I can post a picture. Does anyone have a picture of the "Idler Roller" pulley for reference.
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by z_curtis_s4 View Post
    Go on ecs they have pics of all of them. I replaced mine recently when the crank pulley failed.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by tar View Post
    Was your "Idler Roller" pulley squeaking or you just replaced it to replace it? Also was there any heads up when your crank pulley failed? Any noises, sounds, lack of power? Also did you replace the crank pulley with another OEM one or another brand?
    Apr 05 2016
    Portland, OR
    Idler pulley is a little vague.
    Figure out the source of the noise or at least the rough location of it and we can help you.
    Geoff
    Jul 07 2009
    Socal/IE
    I replaced it because it got gouged up when the crank failed and belts turned into spaghetti. Plus I was in there neways so I replaced as much as I could.
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by whiped View Post
    I wish I knew how to post pictures. I have a picture ready with an arrow pointed to the "Idler pulley." Can someone help guide me how to post picture on here...
    Apr 05 2016
    Portland, OR
    imgur.com then link it here.
    Geoff
    Nov 10 2013
    annapolis, md
    So the pulley that I think is making the squealing sounds is the "Idler Roller Pulley." I have it highlighted and pointing to it with the yellow line. If it's not called the "idler roller pulley" does anyone know the correct name? Who can name this part first!! come on everyone...
    Apr 05 2016
    Portland, OR
    We can't tell you which one if we don't know which one... There are multiple.
    A picture or description will be needed.
    https://www.ecstuning.com/Audi-B8_S4.../Idler_Pulley/
    Geoff
    Nov 10 2013
    annapolis, md
    Hopefully the pictures works this time.
    Apr 05 2016
    Portland, OR
    nvm fixed it.
    OE: https://www.ecstuning.com/b-genuine-...ey/06e903341h/
    After market: https://www.ecstuning.com/b-ina-part...6e903341h~ina/
    I'd do the aftermarket.
    Replacement is easy and might be possible without service position. (Depending on bolt length)
    Geoff
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Is the idler pulley making noise on the main belt (closest to the engine) or is it the one on the front belt for the supercharger?
    OK, now I see the image. It is the supercharger belt tensioner.
    That one is available as an aftermarket MOOG part, if I recall. Inexpensive and easy to replace. It is held by only one center bolt. The new one comes already pre-tensioned in fully collapsed position with a pin through it. Easy peasy to install. You just bolt it up. There is plenty of slack to position the S/C belt. Get everything in place properly and pull out the pin.
    I can't speak for the S4, but on the Q5 3.0T it can be replaced from below without having to put the front in service position. It is tight, but can be done. I think the center bolt requires a "triple square" bit. Don't recall for certain. I replaced mine when going with a Stage 2 tune. I noticed some weakness of the OEM spring. It moved way too easily when taking off the OEM belt. There was only about 14,000 miles on the car at the time. I wanted to make sure it was properly tensioned. Might not have been required, but it made me feel better. The replacement was much stronger.
    I'll look up the part number and source, if interested, PM me.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Nov 10 2013
    annapolis, md
    nvm fixed it.
    SO this is the picture....does anyone know the name of this pulley with the yellow arrow pointed to it? I thought it was called an "Idler Roller" pulley. Anyone with some clarification out there.
    Apr 05 2016
    Portland, OR
    Refresh, I gave you links.
    You might need to put the car in service position to get the bolt out.
    Geoff
    Nov 10 2013
    annapolis, md
    Quote Originally Posted by MSq5 View Post
    Are you positive it's called a "supercharger belt tensioner."
    I just took my car to a shop and they replaced my "supercharger belt tensioner." The squeak went away as I drove the car home and later that same day my car started to make the same squeaking sound again. I was under the impression the "supercharger belt tensioner" which I just had replace and a "Supercharger Belt Idler Pulley" are two different pulley's. The picture I posted has a yellow line pointing at some pulley which I thought was called "Idler Roller Pulley" aka "Supercharger Belt Idler Pulley." Now I'm confused if you think this is called "supercharger belt tensioner."
    Can anyone please confirm or clarify.
    Apr 05 2016
    Portland, OR
    The tensioner pulley is a different pulley...
    OE: https://www.ecstuning.com/b-genuine-...r/06e903133ab/ INA: https://www.ecstuning.com/b-ina-part...6e903133h~ina/
    1 is the tensioner, 3 is the idler.
    Geoff
    Senior Member Two Rings Wreckm's Avatar
    Oct 30 2013
    San Gabriel California
    Idler pulley.
    Nov 10 2013
    annapolis, md
    It's definitely #3 the Idler Pulley. I just got my Supercharger tensioner pulley replace thinking that was the squeaking sound. But later that same day the squeaking noise came back. Is it a big job to replace the "idler pulley?"
    Oct 30 2013
    if you can fit some small hands in there. Most likely service mode.
    Jul 07 2009
    Socal/IE
    Its a service mode required one. Bolt is 2 long otherwise.
    May 17 2012
    Houston, TX
    For the uneducated, what exactly is service mode? Assume you need to set it with VCDS?
    Nov 10 2013
    annapolis, md
    Do you know approximately how long this job would take? Even a rough estimate would be great.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by AKPS4 View Post
    Service mode is pulling the front support forward. No vcds required.
    Shop time is probably like 2 hrs.
    Oct 30 2013
    First time takes a minute. i would say 30 minutes? and thats to get it INTO service mode.
    after that was e z know what bolts to take off.
    Oct 30 2013
    You do need 2 bolts so the bumper hangs on them. i don't remember the exact thread but someone will.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Squeeky noise could also be the other tensioner pulley, for the serpentine accessory belt (drives the water pump, AC, alternator, and power steering pump). I think pulling the radiator support forward, into the "Service Position" is a must....there is hardly enough room to do this when in the Service Position.....The front bumper cover has to come off, then about 12 screws/bolts, and the radiator support and the bumper beam can be pulled forward about 6 inches to get more room between the front of the engine and the back of the radiator/fan assembly.
    Nov 10 2013
    annapolis, md
    So it sounds like its the "Idler Roller Pulley." Do you suggest I buy another OEM "Idler Roller Pulley" or buy an aftermarket one. If an aftermarket one......can someone offer a good brand. Last question is going aftermarket have any positives over OEM? Cheers.
    Sep 24 2014
    Central NJ
    I would stick with OEM, but you will pay a little more $. Try europaparts.com
    Feb 14 2017
    Gulfport, MS
    The tensioner and idler are separate parts. Sorry for misunderstanding the source of the sound. I do not have a part number for the idler pulley.
    For those who need the tensioner pulley, it is Gates 39332. Rockauto has it for about $66. This is made in Germany and appears to actually be OEM. Maybe we can find the idler from Gates?
    Nov 10 2013
    annapolis, md
    Does anyone know the part number for the idler pulley. I looked on ECS tuning for the pulley and there area couple options some with pictures and some not so I'm not sure what one I need for a replacement part. Any help would be very appreciated.
    Feb 14 2017
    Gulfport, MS
    Nov 10 2013
    annapolis, md
    [IMG][/IMG]
    I found this one at ECS tuning. I just want to make sure this is the same "idler pulley" that is in my B8 S4. Mine looks like it has rivots on the pulley and ecs one doesn't really show rivots. Is this the right part for my car?
    Senior Member Two Rings AlexsB5S4's Avatar
    Oct 26 2006
    01 S4
    Sorry to bring this thread back from the dead but any one know the torque spec on the supercharger idler pulley?
    Oct 06 2012
    Minnie Snowda
    40nm
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    This noise started about 5 days ago. Any ideas? It goes away after 5 minutes after a cold start.
    Mar 22 2016
    73 Jimmy 496 BBC
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    I think I hear it, hard to tell though. Probably tough but if the video showed the sound going away that'd help. I swear mine sounds the same though....
    Nov 20 2019
    Canton NC
    Quote Originally Posted by evil35r View Post
    Any luck determining the noise? I have something similar going on.
