Results 1 to 12 of 12
    Dec 07 2017
    Boston, MA
    A5 Upper Oil Pan/Sump Removal
    Hey guys,
    Trying to do a DIY on a fried piston ring. I've got everything off the car and the last thing I'm having trouble with is getting the upper oil pan/sump to detach so I can get to the pistons from the bottom.
    Does anyone have any experience doing this? I've removed all the visible bolts from the bottom but it seems like have to be missing some that I can't see. It just won't come off and I don't want to bang on it too aggressively.
    The engine is still mounted in the car, would like to keep it that way if possible.
    Car is a 2011 Audi A5 Quattro 2.0T TFSI Manual Transmission
    Established Member Two Rings GTDV10's Avatar
    Jun 08 2015
    New York
    The rear main seal is most likely whats keeping you from separating it. You'll have to remove the engine or transmission unfortunately.
    Current- 2010 R8 | V10 | 6MT | Daytona Gray | WC Lathe Werks Shift Knob | 19" Eurospec Rotor Wheels
    Previous- 2016 S5 l Prem+ l 6MT l Sepang Blue l Black/Silver Nappa | RS5 Piano Black MMI Trim l E-codes | Roc Euro Intake l AWE Touring l APR Dual Pulley Setup l Deval Diffuser l 19x9.5 BBS CH-R
    Dec 07 2017
    Boston, MA
    Thanks for this Sep4ng. I started this project thinking that it could be done without removing the engine entirely but you're right. You can't get to to the top two bolts on the oil pan without pulling the engine out completely.
    Junior Member Two Rings
    Apr 26 2015
    New Smyrna Beach FL
    I just had this discussion this morning. On Friday I was in my indy's shop (good friend of mine). They had a VW CC (2.0t) on the lift. Trans was out and I asked about it. Showed me the two upper pan bolts. Unfortunately, they are behind the trans below the rear main. So, engine stayed in but tranny had to come out. I will stop in tomorrow and get a couple pics if they haven't put it in yet if that will help.
    Mike
    Apr 26 2015
    New Smyrna Beach FL
    Here are the photos of the CC's 2.0t engine with the trans removed showing the upper pan bolt locations. (had to edit above post, the holes are below not above-memory was upside down)
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    super nize of you, amaero !
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Apr 26 2015
    New Smyrna Beach FL
    Good Luck!
    Dec 07 2017
    Boston, MA
    Thanks Mike!
    I was really surprised to see how much force the rear main was able to handle. Not that I was going crazy but I definitely pushed harder than I should have thinking the upper pan would be completely free.
    It turns out that the rings looked pretty good, although I was still burning tons of oil. It was the valves that were in the worst shape! You can see one of the exhaust valves on piston 2 (where I had no compression) is completely shot, and the rest of the valves had tons of carbon buildup. Considerable play in some of the valve guides as well.
    May 12 2017
    what is the mileage on your engine?
    Billy
    Avatar Chart
    Dec 07 2017
    Boston, MA
    Quote Originally Posted by wkhanna View Post
    116,000 or so. Well outside of any extended warranty but too soon for this bs.
    May 12 2017
    i have a 2011 A5 2.0t fsi, but with A/T.....hence my interest.....
    sorry you had to do a rebuild....
    you will be replacing the timing chain, tensioner & guides, too?
    Billy
    Avatar Chart
    Dec 07 2017
    Boston, MA
    Appreciate that, never a good time for your car to fall apart but winter is particularly bad.
    I️ replaced:
    Upper and lower tensioner (Guides and chain all looked good so I️ left them)
    Water Pump (This was shot too)
    Piston rings
    Rod Bearings
    All valves, valve guides, seals etc.
    Hoping to get the engine back in the car this weekend.
