Results 1 to 12 of 12
    Established Member Two Rings marto7's Avatar
    May 06 2017
    Sofia
    1.8T with K04-064 turbo
    Hello.I have audi A4 1.8T Quattro and im planning to put K04-064 turbo.I already have the turbo but not sure what else i need.I put:
    - MaxspeedingRods with Glyco sputter bearing,
    - Pistons from S3 with 20mm bolt and Mahle rings.
    - I removed EGR,SAI and N249 Valve.
    - Bailey DV26
    - Ceramic Clutch with solid mass flywheen for up to 450HP.
    - 2x63mm exhaust
    I have also:
    - Intercooler 550x180x65 - 57mm in/out
    - Walbro fuel pump
    I know i need adapter plate for mounting K04-064 to 1.8t.Injectors will be 550cc Bosch, 2.5tdi MAF housing, HKS air filter, Custom downpipe and dont know what else.If somebody knows please help.Im planning to put the turbo on 1.5-1.6 bar.I think its safety on this pressure.
    Dec 25 2004
    Earth
    K04-064????
    The USA version B6 (2002-2005)A4 1.8t had a K03. Modified to a K04-015!
    You need a tune that is specific to the K04.
    Or a manual Boost Controller.
    Highly recommend a K04-064 Specific tune/chip for the engines ECU
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    May 06 2017
    Sofia
    Yes K04-64.With adapter plate can be mounted to 1.8T engine and its very recommended setup.Specific tune is most important but this is in the end of the project.Im asking about something else.A little things that i maybe forged.
    May 06 2017
    Sofia
    Hello again.Im wondering what injectors are the best for me ? Im thinking about Bosch 630cc.Are the better than siemens deka ?
    Jun 26 2015
    Tampa, FL
    Quote Originally Posted by marto7 View Post
    Pick a tune. Get the injectors that your tuner uses.
    Dec 25 2004
    Earth
    In the country you live in...any tuners and or tunes available?
    You need the ECU programmed for the bigger turbo and injectors.
    Or your engine will go "BOOM!"
    May 06 2017
    Sofia
    I know about the ECU.It will be individually tuned on dyno.
    Now i have a question about a tip.I need to make a custom Intake.I will go with 76mm but i want to use something flexible.Can i use something like this - Link ?
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    Any progress on this Marto?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I have been running a KO4-064 for two years. No complaints, lots of fun on a daily driver.
    Jun 01 2013
    EU
    Quote Originally Posted by Kevin C View Post
    What adapter plate is that?
    Mar 28 2015
    Quote Originally Posted by lowlife89 View Post
    CB Auto. No complaints, I have been running it for a few years with no issues.
    https://www.cbauto.co.uk/k04-064-tfs...-adaptor-plate
    Build Thread:
    https://www.audizine.com/forum/showt...6F-block/page2
