Results 1 to 8 of 8
    Senior Member Three Rings zookie's Avatar
    Jul 30 2011
    NKY
    Air Conditioner Compressor Not Working
    2013 S4 Air conditioner compressor no longer comes on. I've done some googling and read some cases of a pressure switch causing the compressor to not come on. Are there are images or documents out there than anyone is aware of that has the location of these and the part numbers? I've seen them in different places on older models but not on the B8/85 S4.
    Figured I'd start by swapping pressure sensors myself and just hope that it isn't the actual compressor. Unless there's a DIY way to test the compressor?
    Fortunately it's the right time of year for the A/C to not function but when set to auto, the fan essentially blows all the time even when the heater is doing the work to keep the cabin warm.
    Haven't pulled VCDS but will tonight.
    Jul 30 2011
    NKY
    Never had to bump a thread here before. Anyone know what I'm talking about? Fortunately it's winter so it hasn't been an issue but spring will be here quick!
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    pressure sensors are housed within the compressor, it's not a serviceable item on the B8.5's
    In VCDS, you should be able to log the output of the compressor under the Auto-HVAC setting. If your compressor is seeing a PWM signal, voltage/amps, but your high side pressures are low, then your compressor does not work. Another way is to measure your low/high side and compare pressure readings; if the compressor kicks on, then the high side should jump closer to the 200psi (depending on ambient temps obviously), but if it remains the exact same or around the low side readings, then something is wrong with the compressor
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by Loe View Post
    I will expand on this. R134 A should read the same pressure as ambient outside temp +- a few when the car is off or A/C not running. if you pressures are way lower than ambient temp then your low on freon and you have a leak. Thats if you haven't gone though a heatsoak on the engine. Also If you can get a friend with R134A manifold gauges it will take about 10 min to check to see if the system is working correctly. Also if you have vag com you can hook up and check for faults in the ECM or HVAC system related to the compressor and monitor temps.
    Jul 30 2011
    NKY
    Just to close off this thread, thank you for the advice. Issue was pressure sensor. Replaced and all good!
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    How did you replace the pressure sensor?
    Sent from my SM-G930VL using Audizine mobile app
    "Big" Mods:
    -APR turboback exhaust w/ gutted HFC
    -Intake
    -Treadstone TR8 intercooler
    -2014 A5 engine to fix the oil issue (REEEEEE)
    -Eurodyne Stage 2 tune (I did it myself. Fingers crossed.)
    Garage:
    2011 Audi A5 2.0T 6 MT
    1978 Dodge W-150 (318 cu. in. V8 w/ 4x4)
    2015 VW GTI SE two door DSG (Wife's)
    Jul 30 2011
    NKY
    Audi did it under CPO because I got busy with work so I had to just get it done. Not sure if I won or lost with the CPO deductible. Sorry not more help.
    Senior Member Two Rings steampunkjunker's Avatar
    Jun 21 2017
    NorCal
    Not true. The AC Pressure Sensor is serviceable and can be replaced without loosing refrigerant.
    https://www.ecstuning.com/b-genuine-...ch/4h0959126b/
    Junker’s 2013 B8.5 S4
    • Suspension: H&R ARBs, CR-15, H&R 10/12mm wheel spacers
    • Braking: Endless MX-72 & RF-650 fluid, StopTech cryo slotted rotors, Tyrolsport brake lines & caliper bushings
    • Motor: GIAC - Stage 2, Redline oil
    • Coming soon: GIAC - TCU, Bilstein B12 Pro-Kit
