2006 Audi A4 Base, FWD, 6 Speed, Engine Code BPG
Exterior Mods
Morimoto Headlight mod
Rotiform BLQ, 19x8.5
Brembo 18Z Calipers w/EBC Yellow Stuff Pads
Relak Carbon Fiber Side Skirts
S-Line Front Bumper w/RS6 mesh grill conversion
Cupra Front Lip
Carbon Fiber Duckbill rear wing (ECS)
Carbon Fiber Side Mirror Covers (ECS)
Carbon Fiber B-Pillars
Fenders rolled and pulled
Smoked side markers and smoked side blinkers
S4 Door Blades
Suspension
Eibach Springs w/ECS Coilover system
RS4 Rear Sway Bar
ECS Rear End Links
ECS Front Sway Bar End Links
Performance Front Sway Bar Bushings
Ultra Racing Upper Strut Bar
SPC Adjustable Upper Control Arms
ECS Billet Subframe Steel Bushings (Front)
Interior Mods
Custom Flat Bottom Steering Wheel
BFI Shift Knob
Custom Interior Wrapped Trim
Custom Suede Wrapped Black Headliner
Black Interior Swap
B6 Front and Rear Recaro Seats
Podi Gauge Pod w/Boost Gauge
Innovative Wideband in Custom Vent Pod
VFiz
R8 Pedals
Wrapped e-Brake Handle
Blackvue Front and Rear Camera
Different Head Unit (S100 Android)
Kicker 10" sub in Custom Side Mount Trunk Box
Greddy PROFEC Electronic Boost Controller
Go Fast Mods 405.6 WHP/328 ft/lbs Tq (prior to forged internals; stock block; stock clutch)
Motoza Tune - Pending - Still getting tweaked
PagParts Turbo Kit (purchased from Mitchbartoo)
PPT Manifold
Borg Warner EFR 7163 Turbo
Tial MV-S 38mm Wastegate
Custom Downpipe
RamAir Cold Air Intake
IE Adjustable Camshaft Gear
FluiDampr Pulley
Intake manifold flaps delete
B8.5 Throttle Body (3" opening)
RS4 Injectors
APR HPFP
155 Bar Upgraded PRV
JHM DW200 LPFP (died) - new pump is Walbro 450
Water Methanol Injection Kit (2 nozzles), Tank in the Trunk
Custom Catback Exhaust
Torqbyte PM4
Mishimoto Catch Can
ECS Oil Filter Housing
ECS Engine Mounts
Apikol Transmission Mount
Polyurethane Snub Mount
Treadstone TR18 Front Mount Intercooler
Forged H-Beam Rods
King Racing Bearings
JE Pistons 82.5mm (standard bore), 8.5:1 compression ratio
IE Titanium Valve Springs & Retainers & valve stem seals
Ferrea & Supertech Titanium Valves
ARP head studs & cam girdle studs
Clutchmasters FX350 Flywheel & Clutch Combo
GFB DV+
2.0T oil pump w/balance shaft delete
So I've had my car since 2006. I've been the only owner of it and I've made lots of choices and gone through lots of parts and wheels. I've done a pretty good job taking care of it and just wanted to document a few things from start to now. Please feel free to comment/hate/like. I'm pretty thick skinned.
First two things I did was install Eibach springs and get some wheels. I ran these RPM 505's for probably about 7 or 8 years before finally getting some different wheels. Oh, and I tinted the windows.
After moving from Germany to Wyoming I really didn't do much to the car and just kind of neglected it. But then I moved to California and started giving it some love. Bought some new black Rohana 20's and started with a black theme with black grill and some black S4 door blades. Also threw some Relak skirts on.
Eventually got a custom exhaust put on.
With some exterior mods I started focusing on fixing the car and modifying it engine wise. Especially when I decided to go with a JHM tune.
At that point the engine mods were:
Test pipe
JHM upgraded HPFP
Full exhaust
Front mount intercooler
Intake
Wheel swap time to some Rotiform BLQ's (I still have them but I curbed one and have to try to fix it)
With this faze came some 18Z upgrades, custom made steering wheel, and BFI shift knob.
I said to myself, "This car is fast, lets put it on a dyno and see what kind of power I'm making!"
Disappointment...
So with that disappointing result I started doing some more exterior work.
Changed rims - Bronze JNC 026's - rears are19 x 10.5’s, ET25 w/ 275/30/19's !!!!
Rolled the rear fenders
Got the S4 blades painted red to match the car
Morimoto headlight conversion and new lenses
