Results 1 to 40 of 44
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    limits of 4.0t and 7-speed stronic trans???
    Trying to find some factional info on this subject. ive searched to no avail but has anyone found out true limits so the 7-speed trans over the zf in the rs7?
    Nov 06 2012
    Pennsylvania
    Dont think its been found yet. In for more info.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Current daily- '13 S6 - EPL stage 2
    Backups '08 A4 2.0 and '10 A6 3.0t
    Past fleet
    '07 RS4 misano red on black
    '05 S4
    '06 Jetta 2.5
    '01 TT 225
    Jul 01 2012
    Quote Originally Posted by brian_216 View Post
    Well what's the highest numbers that have been made so far
    Sent from my LG-H918 using Tapatalk
    Nov 06 2012
    Pennsylvania
    Bigger question to ask, who has had a stage 3 car the longest / most miles
    Past fleet
    '05 S4
    '06 Jetta 2.5
    '01 TT 225
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    I haven't seen posts where people who are tuned having issues. I think I see more axle problems than the DSG when it comes to limits.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Feb 15 2011
    Northern VA
    The 7sp DSG used in the S6/7 is rated at max 450ft/lb of torque. This obviously doesn't mean it can't be exceeded, but to maintain reliability and longevity Audi has set that number as the max.
    The ZF is rated at 660Ft/lb
    Jul 01 2012
    Quote Originally Posted by Yeoman View Post
    I've seen what they are "rated" at but what the max people are doin with them currently. Like I know their are stage 3 cars but are they having trouble with the torque or what's the highest numbers so far
    Account Terminated Two Rings
    Apr 26 2016
    London
    That 660 or actually 663 is the theoretical limit of the ZF 8HP90. The 90 is for 900nm of torque which equals 663 ft-lbs. Only Audi's highest torque models (turbo diesels) have this transmission. The RS7 and S8 use the 8HP70 which is only rated for 700nm or 516-lbs of torque; it's no coincidence that the RS7 and S8's factory torque numbers are this exact number.
    The DL501 is actually rated for 406.6 lb ft (550 Nm) at 9000 rpm. Again, no coincidence that the S6 and S7 have advertised torque figures of 406 ft-lbs...
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Rs7 p models have 556 ft lb
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Apr 26 2016
    London
    Not sustained though; it's an "overboost" feature only. Only available for a few seconds. That's how they're still able to justify not exceeding ZF's advertised max. torque ratings. Same thing that Porsche has been doing for the past decade or two.
    "Highlights: The RS7 Performance adds carbon ceramic brakes, a new sport suspension, a new front end treatment and unique tailpipes over the 'basic' RS7. It makes 516 lb-ft of torque to go along with its 605 hp, but with the overboost function drivers can get an extra 37 lb-ft for short amounts of time. The RS7 performance model sprints from 0 to 60 mph in just 3.6 seconds and reaches a top track speed of 190 mph."
    Read more: http://autoweek.com/article/car-revi...#ixzz509DJMtEO
    Quote Originally Posted by DGVR6 View Post
    Veteran Member Three Rings Marc R's Avatar
    Jan 29 2017
    Amsterdam
    My Stg 3 is now doing 820Nm of torque(approx 610 ft lb), no issues with trans in term of "in gear" performance, however the engaging point is a thing that irritates me.
    This has been present on the car since I have it, so also BEFORE the tuning, i dont see this as a tuning related issue but more of something that this specific to this trans because more people seem to have this issue with the 7 speed S-Tronic.
    TBH this makes me looking at an RS6 earlier than I thought at first
    From what I read the RS6/RS7/S8 tiptronic doesn't have the clutch issue
    'S8 plus moonlightblue DS1 stage 1
    SQ5 FY ABT "moonlightblue Hybrid turbo 505HP/580 ft-lb(gone)
    RS6 Avant ABT MY '16 Ferrari Blue pozzi (gone but not forgotten)
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by soccerking93 View Post
    And therein is the likely factor in why the DSG in the S6/7 can handle so much torque in a tuned state without a problem. The mechanical strain of 406 lb-ft at 9000 rpm is far more than 600 +/- lb-ft at 5000 rpm.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Sep 19 2014
    Newcastle
    I read that the next rs6/7 Will go back to an s tronic box so can't be weak if on that are. My stage 1 s6 is making over 600flbs and no issues and I beat on it.
    Sent from my SM-G920F using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Feb 25 2014
    Texas
    Quote Originally Posted by Marc R View Post
    Marc, how is your stage 3 car only making 610 torque?
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    From what i know, Marc still needs to go in for final tune (bought same cooler as me but still has to install it). Once that is done he was going to head back to the tuner and fine tune further.
    My stage 2 pulled over 890Nm. But we reduced it to 877Nm, 587ehp, 527whp.
    Sep 07 2010
    Belgium
    @Marc: did you try the vcds clutch recalibration? Also didnt found the time to do it :(.
    Sep 19 2014
    Newcastle
    Quote Originally Posted by Dasquade View Post
    Don't JD advertise those figures for stage1 1 or 2? 820nm is low for stage 3
    Sep 07 2010
    Belgium
    Quote Originally Posted by pez81 View Post
    Like said, they did his RS turbo's and put a temp tune on it :).
    From what i think, they did gave it enough boost etc at the high rpms (afaik where you get your max. HP) but kept the boost lower at low-mid rpms (afaik where you get your max. torque).
    JD's S6 (semi converted RS6 avant with stage3) is claimed to pull 720Hp (not sure if that is WHP). I forgot to ask what torque they set it at.
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Jan 29 2017
    Amsterdam
    Dasquade is corrct, my IAT were too high, bought that cooler and still need to go back to re-tune it....that is why.
    But the car feels fast and runs like a champ tbh
    JD's S6 initially had 750 HP
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    about 22,000 miles on my setup and completely hiccup free, launch on the street a bunch and a few times on the strip. no slipping, bucking or tall engagment points(i have the TCU tune too)
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Feb 25 2014
    Texas
    Spero has been stage 3 the longest and claims zero issues as well. I believe he's going on 24+ months now.
    I still haven't attempted launch control since getting flashed stage 3. I lowered the launch RPM to 4k, we'll see how it does
    10.65 @ 129mph
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Subbed for more updates and info.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
    Jul 01 2012
    Has anyone figured the math on what the equivalent of the torment the trans would be taking at 406 lb-ft at 9000 vs what it would be at a lower rpm? Such closer to redline. Maybe could figure a better average number to base the max torque numbers. Being of course we wont make it to 9000 rpm but i better the trans could maybe hold 6-700hp at 6500 like its been but im sure theres some math that could be done to give us better numbers. I would do it but i hate math lmao
    Apr 26 2016
    London
    Why would the trans have a different torque rating at 6500 than 9000? I don't see how that would change based on RPM.
    Mar 26 2010
    US
    406 ft lbs at 9000 rpm = 696 hp
    406 ft lbs at 6500 rpm = 502 hp
    http://www.metaris.com/hp-relations.php
    BMW M3 Competition X-drive
    Apr 26 2016
    London
    Right but what I think you guys are missing is the simple fact that transmissions are rated in terms of torque, not horsepower. It's not horsepower at 6500 or 9000 RPMs that's the problem, it's torque at lower RPM. This is why you often see tuners capping torque and making it a very gradual curve on certain cars that are running stock components. It's because it's torque at low RPMs, not HP at higher RPM that kills clutches and transmissions. The 406 ft-lbs number is what the manufacturer has deemed the max. torque capacity after taking into account all kinds of different factors. Now whether or not this is conservative and can be exceeded is certainly up for debate. But Audi has been sure to not exceed this 406 number on any DL501 equipped cars at ANY RPM.
    Quote Originally Posted by wwhan View Post
    Sep 19 2014
    Newcastle
    I don't think you're right here. they probably choose 9000rpm at 420 because that's what they have tested at without failure. like someone said 420lbs at 9000rpm is way higher than that. that's my guess. looks like audi is going back to the dual clutch for the next rs6/7 so can't be that weak. also many have been running over 600ft lbs for years with no issues. until someone destroys theirs there is no real way of knowing
    Apr 26 2016
    London
    I'm sorry but this is a completely inaccurate statement. The lower the RPM, the more strain the same torque will have on components such as the transmission.
    Quote Originally Posted by VVG View Post
    Apr 26 2016
    London
    You're assuming the next RS6/7 will have the DL501 which it most definitely will not. I'm not saying all dual clutch transmissions are weak, only that a max. 406 ft-lbs of torque rating at 9,000 RPMs doesn't mean the transmission can withstand more torque at a lower RPM using the same manufacturer's rating. Like I said, it's certainly debatable whether or not that 406 number is conservative and can be exceeded. The Germans have very high durability standards. The transmission has to last x number of KM under x, x, and x conditions.
    Feb 25 2014
    Texas
    There's no debate that the DSG can handle more than 406 ft/lbs for extended periods of time. But I agree that the magic number or range is yet to be seen. Guys have been running over 600 ft'lbs for multiple years driving the piss out of their cars without trans failures or even issues. The weak link for these cars are the axles. Those will always go before the trans with these cars
    10.65 @ 129mph
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    Can I get some cliffs on this? I’ve not heard of this, and my Stage II car S6 is exhibiting some strange shifting and clutch engagement behavior. Would love to learn. More about what I could achieve with VCDS...
    Sep 07 2010
    Belgium
    Quote Originally Posted by jsilas View Post
    http://www.audizine.com/forum/showth...ce-Calibration
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Angular Momentum
    Sep 19 2014
    Newcastle
    Quote Originally Posted by nefkntym View Post
    Angular Momentum
    there's always someone smarter. thanks Mr science guy! didn't know the terminology
    Dec 29 2015
    WA, PNW
    Many thanks, sir
    Established Member Two Rings Dirty_Bourbon's Avatar
    Nov 06 2015
    2021 GLB
    Morristown, NJ
    Can i get an update on this- who's got high mileage w/ Stage 2 or greater.... Any issues?
    B9.5 S4 Quantum Grey/Grey
    +JB4 Module (Map3 93 oct)
    +VPS Mid Muff Delete
    +CTS Inlet paired with Roc Euro Intake + ECS Silicon Coupler
    ________________________________
    In Remembrance:
    B9 A4 SLine B/Br
    B8.5 A4 SLine Competition B/Optics[/FONT]
    Sep 07 2010
    Belgium
    99.1xxkm here, forgot at what km i went to stage 2 but roughly 15.000-20.000km i think, before stage 1 at around 40.000km i think.
    Beside known and obvious clutch wear (recalibrated once), no issues at all here :). As a mather of fact (bit unrelated tough), she is driving super smooth again since i swapped the NGK race plugs out and put OEM "M" revision plugs and milltek X pipe. No longer stutter at 4.000rpm/low-semi boost.
    Overall beside one faulty turbo pressure sensor, no other drama :).
    Nov 01 2015
    13 S6, 08 911 turbo, 04 LS1/T56 IS300, 02 VFR800, 93 MR2 turbo, 14 Tundra, 17 MKZ hybrid, 19 Q7
    LaGrange GA
    APR has a C7 S6 they use for development. I can't imagine there are many people (if any) that put as many *hard* miles on a 4.0 DSG as they do. I think they said they have put ~30k miles on it and it has 70k~80k total miles with no transmission issues.
    13 S5
    19 Q7 Prestige, black optics, luxury, cold weather
    14 911 Turbo S 68mm turbos, methanol injection, Kline headers and exhaust, Cobb AP, AMS intercoolers, IPD y-pipe and plenum, BMC filter
    14 Panamera Turbo Fabspeed downpipes
    93 MR2 turbo gen3 3sgte, t3/t4, 264s, AEM
    05 C6 Corvette 6MT, built engine, twin turbo, methanol injection
    02 VFR800
    19 RAM 1500 Limited
    Veteran Member Three Rings 1flossedS4's Avatar
    Jun 11 2013
    Albany, NY
    This is why I bought an RS7 with the ZF. It's a stronger unit.
    Bigger problem is the engine issues with turbos on the 4.0t in my opinion.
    WTB: 2017-2018 A6 Competition Package PM ME
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by 1flossedS4 View Post
    Easily fixable though, just install the updated feeder screen, shorten your OCI and use good oil, you'll be good for a long time. (Hopefully forever, we'll see.)
