    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Will a CTS turbo downpipe cause a CEL?
    I recently bought a CTS turbo with a hi flow cat, i have yet to install it i was waiting for my Dinan exhaust to come in (came in yesterday) and i want to make sure it won't throw a CEL. I'm aware that it is very likely it will throw a CEL so a follow up, will an O2 spacer help to not throw a CEL?
    I attached a couple images of the exhaust and the downpipe, the springs are Neuspeed. Thanks
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Most likely YES unless you have a tune. A O2 spacer may help it not come as frequent but inevitably it will always cause a CEL unless u are tuned. I have a catless CTS but later added a cat(because of smell) and I am running a jb1 and it throws a cel but I find it to throw it when the car is not 100% warmed up and I am in a high gear in low rpm and throttle it....
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by jiannu View Post
    Ok that's what i was thining, i was planning on going unitronic stage 2 soon anyways since i have the supporting mods for it
    Sent from my SM-G930V using Audizine mobile app
    Aug 23 2014
    Philadelphia, PA
    Yes it will throw a check engine light. Stage 2 tune will clear it but you can still have inspection issues as the tune just codes it out. But an o2 spacer helps correct it. Just is because the downpipe flows better
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by ModdedEuros View Post
    Do you guys have the stage 2 up on sale? And what do i need to buy in order to flash it at home?
