Results 1 to 8 of 8
    Established Member Two Rings TMeschke's Avatar
    Sep 20 2016
    2017 Volkswagen Alltrack SEL
    Minneapolis, MN
    Question How to Bypass 1.8T A/C Compressor?
    Hey all,
    A while back my A/C stopped working, and now my compressor has just started screaming like a banshee when the car is idling. Can't decide if I want to try to fix to A/C system or just delete it. For now I just want to stop the squealing, so I was planning to bypass the A/C compressor.
    I searched through forum and found some information on doing this, but nothing detailed. From my understanding a Dayco 450K6 (Click) is the belt that I will need. What I'm not entirely clear on is how to actually route the thing. If anyone has any pictures or info on this, that would be terrific.
    2003 Audi A4 1.8T Quattro 5MT - Garrett GT28RS, ATP T25 Manifold, IE Returning Fuel Rail w/ 1000cc Injectors for E85, Motoza BT Tune, Brembo 17Z Front Calipers, CTS FMIC, Mishimoto Oil Cooler, B&B Sport Exhaust
    2017 Volkswagen Alltrack SEL - APR Plus Tune, APR TCU Tune, AWE Touring Exhaust, Yakima Offgrid Roof Basket, 40" RC Light Bar
    Sep 20 2016
    Minneapolis, MN
    Finally found a good picture of the serpentine belt. Pardon the horrible drawing, but would this be the new route of the belt? Can anyone confirm?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Yep.
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    x2 just did this using this belt:
    Got it from ebay.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    I've had this done for about 5 years and it works just fine, i removed the entire system up to the firewall port.
    belt i use is a GoodYear Gatorback 4060420 6pk1065
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Sep 20 2016
    Minneapolis, MN
    Just realized I never updated this post.
    Got the new belt put on a while back. Only took about 20 minutes, mostly just getting the car raised on the belly pan off. I tried rotating the A/C compressor by hand while I had the belt off and it felt terrible. It made a nice grinding noise and put up a fair resistance. Car definitely seems to idle a bit more smoothly now and the grinding noise is gone. Who needs A/C anyway .
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    ETKA says this is the belt for non AC 1.8T B6: 06b145933. It should be the same for all years and VINs. It has a length of 1080mm and its equivalent is Gates 6PK1078.
    LE: The Gates 6PK1078 is too short. I think it's because cars without AC didn't come with this big roller:
    The problems stems from me not being able to find that Dayco belt over here. I've hopefully ordered a matching Gates and will report back.
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    Front drive pulley bearing failure is the #1 cause of "screaming compressor" and is fixable by only replacing the bearing cartridge, as detailed here. This avoids the major hassle & expense of opening the refrigerant circuit and replacing the compressor, the latter being very often 100% okay. That pulley bearing is an Achilles' heel of an otherwise very durable compressor. Also discussed is a bypass belt any U.S. parts store will have in stock.
