I am finding a lot of conflicting information online.
I have been using the HEAT RANGE 7 plugs below for the longest time, since that is what ECS tuning is calling ONE STEP COLDER than stock.
https://www.ecstuning.com/b-ngk-part...four/bkr7ekt1/
But if you look at the NGK website, their factory replacement plug is a heat range 7. Again see below.
http://www.partcat.com/ngk
This is a Spark Plug Cross reference website which states that the factory NGK heat range is indeed 7. Denso is 22 which matches up. See below, two links with lots of plugs.
http://www.sparkplug-crossreference....t/vw/06H905621
http://www.sparkplug-crossreference....GK_PN/PFR7S8EG
And here, JHM is stating the same information as ECS about heat ranges. Their Bosch plugs state heat range 6 is OEM, but as a matter of fact based on these other sites, it is actually heat range 5 that is stock for the Bosch plugs on the 2.0T FSI engine. JHM site below,
https://jhmotorsports.com/catalog/pr...t/category/44/
Now when i go on the genuine Audi parts site they have this part number listed as stock. 06H905621 Based on the reference website that correlates to heat range 7 for ngk and 22 for Denso.
https://genuineaudiparts.com/parts/2...iagram=1398235
So who is actually correct? Is GAP wrong? are all the cross reference sites wrong? Or are both JHM and ECS wrong?
Should we actually be buying heat range 8 NGK for stage 2 and up? or heat range 4 Bosch if you will?
