I didn't want to:
- glue some big thing to a conspicuous spot on my dash
- have the phone on top of the dash or on the windshield anywhere
- screw anything in anywhere and put holes in things
No manufactured mount seemed to fit and hold the phone where I wanted, so I brainstormed my own simple one.
Parts:
- small black hinge
- gorilla glue
- electrical tape (or plastidip)
- two medium diameter neodymium magnets
- heavy duty black velcro
I tacked the two magnets side-by-side on one half of the hinge using some gorilla glue, then wrapped them in black electrical tape. I used heavy duty velcro, the kind made entirely of stout plastic rather than the normal velcro with the fuzzy size and plastic loop side. I wanted the mount to stay put when it's installed, and it would wiggle a bit with normal velcro. I cut down the velcro strip to be only about the size of the half of the hinge to which it is stuck. The other side of the velcro is stuck inconspicuously on the underside of the lip in the dash below the center vents. The phone is held firmly at an angle above the head unit and securely against the dash. It slightly obscures part of the left vent but doesn't obstruct the vent "handle" or the ability to adjust it. The neodymium magnets are very strong and the phone doesn't budge at all.
I have some black plastidip, and will dip the half of the hinge with the magnets instead of wrapping them in electrical tape, for a slightly better finish. I'm also going to use a marker or some black nail polish to blacken the edges of the white adhesive strips on the velcro. That should clean up the look pretty well. The mount is very strong, cheap, and easy to make. It won't damage your dash, and it's very easily removed altogether. I think it looks at least as good as any other solution, or at least it will after I black out the white adhesive strips and switch to plastidip.
The phone is a Samsung Galaxy Note 8 in a Spigen case with a metal plate for magnetic mounting.
Thought I'd share this simple DIY to help out anyone else not satisfied with what's for sale. Cheers.
///Mike Westermann
San Francisco, CA
[email protected]
