Sorry if this is an old issue as I have read lots of similar posts and would like some clarity.
The ABS and traction control light does not come on straight away but after I drive for a few miles. I first thought it was the brake switch, I have removed and cleaned off the dirt build up on the contacts inside, it seemed to help for a couple of days but the lights come on still so it could be I need a new brake switch.
Questions:
If the dash lights do not come on straight away, does this rule out a faulty ABS sensor? Or could one of the wheel sensors need replacing, if so how to tell which one does?
The other thing is, I adjusted the steering column slightly and is seems that since then the ABS and traction lights come on, it may be the angle sensor perhaps?
Thanks
