Results 1 to 13 of 13
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    Real-world experience with 275 tires on OEM 20" wheels of C7.5 S6
    Hi all,
    I've been searching high and low for information on this, and unfortunately all I've been able to locate is a bunch of information on S7s, or S6s with aftermarket wheels of various offsets. What I'm interested in is whether or not the stock 20" wheels on the 2016+ S6 can support a 275/35-20 tire (stock is 255/35-20). In the springtime the winter wheels/tires will come off, and my stock Pirellis are near their end of life, so new tires are needed. I'd like to go a bit wider, and I'm interested in understanding what will fit. If you've done +width on stock 20" wheels, photos of your setups would be very helpful too.
    The car in question:
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    IMO, 275s are too wide to run on an 8.5" wheel.
    For what it is worth on my S6 I run 275/30/21s on my OEM 21" 5 Arm Rotor wheels which are 9" wide.
    Apr 29 2016
    2021 Q7 Prestige
    Los Angeles, CA
    275 is usually for 9" wide to say 10.5" wide. For 8.5 265 would be the widest. But that is just my experience on this and past cars.
    Mar 14 2016
    Cleveland, OH
    It will make it floaty and the cornering will be mushy and feel imprecise. I would stick to 255 for now. I went to 265 and 9.0" wheel and great balance between ride quality and cornering.
    Established Member Two Rings Velopod's Avatar
    Mar 11 2017
    S7, Boxter S, RX350, HD Street Glide Special
    Cincinnati, OH
    Here is a 275/35-20 Michelin Pilot Sport AS 3+ on Hartmann Replicas ... but they are 9" wide. 9 to 9.5 is about perfect. It would be pretty squished on an 8.5" rim.
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I run 275 continental dws06 on my stock s7 20's in the winter. OEM is only 10mm smaller tread (265) but adds $150 per tire. The difference is moot.
    Sent from my SM-G950U using Tapatalk
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by ericw. View Post
    Aren't stock S7 wheels wider than stock S6 wheels? No way I would put 275s on an 8.5" wheel. The contact patch won't sit square on the road. 275s would work best on a 9.5-10" wide wheel. An 8.5" wide wheel works best with a 235-255 tire.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Apr 23 2011
    Sac Area, CA
    Quote Originally Posted by VVG View Post
    Aren't stock S7 wheels wider than stock S6 wheels? No way I would put 275s on an 8.5" wheel. The contact patch won't sit square on the road. 275s would work best on a 9.5-10" wide wheel. An 8.5" wide wheel work best with a 235-255 tire.
    I'm not sure but I thought they were 8.5" wide.
    IG @lolzhax
    //AGILITYDRIVES.US
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    My A7 has the 20x9” forged Fuchs, and I am running Nokian Zline 275/35s. They sit flush on the wheel and sidewall doesn’t have distortion.
    275 vs 255 is not that large of a width increase. 2 cm or about 3/4” wider. Only on same bar and and model. There are many variations in tire profile for same size. Some are wider and square at tread edge block and some are more rounded.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Senior Member Two Rings IceyTys's Avatar
    Jul 12 2012
    2020 RAM 1500 Limited
    Dallas, TX
    Quote Originally Posted by jsilas View Post
    Hi all,
    You could run 275 on the factory rim, however if you were to run that wide I would recommend moving down a series to 30 vs 35, this will keep the sidewall firmer and reduce side to side play when cornering, it also should keep your tire size within 2% of what you have now. Check out www.willtheyfit.com and you can plug in the numbers of each tire/wheel set up. I see youre in Seattle, do you ever do any of the meet ups? Beautiful car BTW!!
    My Audi life:
    Current
    2013 - S6 - Brilliant Black
    Gone but not forgotten:
    2003 - TT 1.8T 6MT - Quattro Roadster - Silver
    2010 - S5 6MT - Prestige - Phantom Black
    2004 - A4 1.8T 6MT - Ultra-Sport - Brilliant Black
    2003 - A4 1.8T - Ultra-Sport - Dolphin Grey
    Dec 29 2015
    WA, PNW
    Quote Originally Posted by IceyTys View Post
    Thanks for the input man - much appreciated. I may just end up sticking with stock sizing but go with better tires (Michelin PS4S).
    I've not attended any meet ups yet, but I would like to. Would be cool to see what others have around the area.
    Jul 12 2012
    Dallas, TX
    Cool....if youre on facebook check out 2zero6 Audi's there are a few of us C7 owners on there and we meet up pretty often. They usually do a dinner meet up each Thursday evening around Tukwila area. Also check out on FB Northwest Audi Exclusive or Seattle Cars and Coffee.
    My Audi life:
    Current
    Dec 10 2013
    2013%20C7%20S6
    Fudoli
    Some actual calculations for anyone still looking at this... overall difference appears negligible, but provides .3" more sidewall to deal with poor road conditions, as well as .8" in additional width, and .6" in diameter (see attached).
