Instructions for use
Please note:
This TSH article may be used only if the equipment
combinations, on-board control units and event memory
entries specified below apply to the vehicle.
Diagnostic trouble codes
Diagnostic address Diagnostic trouble code Fault symptom Storage state
0001 - Engine Control Module 1 P227900: Intake Air System Leak Intermittent
0001 - Engine Control Module 1 P050700: Idle Control System RPM Higher than Expected Intermittent
________________________________________
Technical Service Bulletin Transaction No.: 2040644/8
17 MIL on; whistling noises from engine compartment (DTC P2279 and/or P0507) Release date: May 25, 2017
Condition
REVISION HISTORY
Revision Date Purpose
8 - Revised header data (Added engine code)
7 02/14/2017 Revised Required Parts and Tools (Updated part number)
6 01/19/2017 Revised Warranty (Updated time units and Claim Type)
• A metallic whistling or grinding sound is heard from the engine compartment when the vehicle is at idle speed.
• The sound usually only occurs when the engine is warm.
• The MIL is sporadically on.
The following DTCs are stored in the engine control module (ECM), J623 (address word 0001):
• DTC P2279 (Intake air system leak)
• DTC P0507 (Idle control system rpm higher than expected)
Technical Background
A leak in the crankcase breather module (pressure regulating valve) can cause this condition.
Production Solution
Fabric reinforced internal membrane of crankcase breather module.
Service
1. Perform both of the following checks before proceeding:
• Compare the sound of the vehicle to the sound in the video located at:
https://audi-external.kzoplatform.co...swf/player/311 (Figure 1).
• Open the filler cap to check whether the sound is affected when the filler cap is open.
Figure 1. QR code for viewing the video with a QR code reader on phones and tablets. Alternatively, the video can be accessed through computer internet browsers at the link provided in this bulletin.
2. If the sound of the vehicle matches the sound in the video and the sound is affected when the filler cap is opened, replace the oil separator breather module.
Warranty
Claim Type: • 110 up to 48 Months/50,000 Miles.
• G10 for CPO Covered Vehicles – Verify Owner.
• If vehicle is outside any warranty, this Technical Service Bulletin is informational only.
Service Number: 1726
Damage Code: 0050
Labor Operations: For A8 and S8:
Oil separator breather remove +reinstall 1753 1971 20 TU
Air intake distributor remove + reinstall 2446 1921 470 TU
For S6 and S7:
Oil separator breather remove + reinstall 1753 1971 20 TU
Air intake distributor remove + reinstall 2446 1921 600 TU
Additional labor for adjustment of ACC, top view camera, and night vision, if necessary based on vehicle equipment See Elsa See Elsa
For RS7:
Refrigerant drain + fill 8703 1750 40 TU
Air intake distributor remove + reinstall 2446 1923 690 TU
Diagnostic Time: GFF – Checking and clearing fault codes included in existing labor operations 0150 0000 10 TU
Road test prior to service procedure 0121 0002 10 TU
Road test after service procedure 0121 0004 10 TU
Technical diagnosis at dealer’s discretion
(Refer to Section 2.2.1.2 and Audi Warranty Online for DADP allowance details)
Claim Comment: As per TSB #2040644/8
All warranty claims submitted for payment must be in accordance with the Audi Warranty Policies and Procedures Manual. Claims are subject to review or audit by Audi Warranty.
Part Number Part Description Quantity
079103542E Oil separator 1
079129717J Gasket intercooler left 1
079129717K Gasket intercooler right 1
N 90442501 Retaining clip 2
N 90489801 Retaining clip 2
N 90409501 Retaining clip 2
079145818 Gasket throttle body 1
079145417B Gasket recirculation valve 2
WHT 001011 O-ring 1
G 013A8J1G Coolant additive 1
Outside material Distilled water (obtain locally) As needed
(Max $10.00)
Additional Information
All parts and service references provided in this TSB (2040644) are subject to change and/or removal. Always check with your Parts Department and service manuals for the latest information.
©2017 Audi of America, Inc. All rights reserved. Information contained in this document is based on the latest information available at the time of printing and is subject to the copyright and other intellectual property rights of Audi of America, Inc., its affiliated companies and its licensors. All rights are reserved to make changes at any time without notice. No part of this document may be reproduced, stored in a retrieval system, or transmitted in any form or by any means, electronic, mechanical, photocopying, recording, or otherwise, nor may these materials be modified or reposted to other sites without the prior expressed written permission of the publisher.
Based on the TSB and other threads about the parts required to perform this job, expect to spend around $500 for the parts listed below:
- 1x 079103542E – SEPARATOR
- 1x 079145818 – THROTTLE BODY SEAL
- 1x 079129717K – PASSENGER SIDE GASKET
- 1x 079129717J – DRIVER’S SIDE GASKET
- 2x 079145417B – BYPASS VALVE SEAL
- 2x N90489801 – CLIP
- 1x N90409501 – CLIP
- 3x G13 Coolant (1 GALLON)
Tools: I ended up using the following tools for the project. Not too many considering all that you are removing to gain access to the culprit, but a couple were new to me.
- 7mm nut driver
- Torx bits (T20, T30)
- ¼” drive extensions
- Hose removal tools
- Body clip removal tools
- Pliers for removing clamps
- Hose clamp pliers (for crimping one-time use clamps)
- Coolant filling system (I used the Schwaben one from ECS)
- Triple square bit for removing undertray
- Mirror
- Ramps
Step 1: Get your car on the ramps and remove the engine cover, airbox, and airbox-to-turbo inlet accordion hoses. Insert shop towels into turbo inlets to ensure no dirt/debris gets into them:
Step 2: Use compressed air to blow off the throttle body area of debris. Using a T30 Torx, remove the three bolts from the driver’s side bypass valve-to-throttle body connection (The longer bolt goes on the outside):
Step 3: Do the same for the passenger side. Insert shop towel to ensure no debris goes into the holes:
Step 4: Using a 7mm nut driver, loosen the clamps on the turbo-to-throttle body tubes.
Step 5: Disconnect the black and brown connectors from the bypass valve assembly on each side:
Step 6: Using a screwdriver and some anger, remove the clamp from the turbo inlet-to-bypass valve on the driver’s side. Then, remove the bypass valve assembly from the driver’s side:
Step 7: Remove the clamp holding the passenger side wastegate hose to the intercooler. Remove the hose and push it off to the side:
Step 8: Using a T30 Torx bit and extension, remove the 6 screws holding the throttle body to the intercooler:
Step 9: Using a hose tool to wedge under the hose, loosen the turbo-to-throttle body hoses. Push the throttle body aft a bit, then lift up over the little lip on the intercooler, then forward to remove the throttle body. Before you can remove the throttle body, there are two sensors on the underside. Pull the grey tabs up, then push in to release both connections. The one with the green wire goes on the passenger side, brown wire on the driver’s side):
Step 10: Remove the two 5mm bolts holding the driver’s side turbo inlet to the turbo.
Step 11: Using a screwdriver and a bit more anger, loosen the tube connecting the driver’s side turbo inlet to the oil separator. Remove the tube and the entire bypass valve/turbo inlet assembly should be free:
Step 12: UNDERSIDE – Using a triple-square bit, Philips screwdriver, and T20 Torx, start removing the undertray directly below the engine.
Step 13: Using a T20 Torx and plastic rivet removal tool, remove the two plastic rivets and 8-ish screws that hold the front wheel liner to the bumper and fender. Do this on both sides.
Step 14: Using a T30 Torx, remove the four screws holding the bumper undertray to the radiator support.
Step 15: Remove the bolts that hold the bumper to the lock carrier between the grill and headlight. One on each side:
Step 16: Gently pull on the rear edge of the bumper where it meets the fender outwards, until it becomes dislodged. Do this on both sides.
Step 17: Using a body removal tool, lift up on the two plastic rivets near the center hood latch. Remove the cover to expose the area behind the grill.
Step 18: Disconnect the front camera, night vision, and some electronics box from behind the Audi emblem. Slowly lift and pull forward the bumper. Exposing a gap between the bumper and headlights, reach down and disconnect the ACC sensors on each side, as well as a connector below where the passenger headlight was. Finally, with the help of a friend, remove the blue clip from the headlight and night vision washers, then unplug the hose, attempting poorly to cap off the torrent of washer fluid going onto your shoe. Remove the bumper:
Step 19: Disconnect the A/C pressure sensor, ambient air temp sensor, and both horns (one per side). Dislodge the retaining clips from the crash beam and ensure that the front wiring harness is free from the crash beam. Loop it up the driver’s side fender and out of the way:
Step 20: Using a T30 Torx, loosen the 4 bolts holding the driver’s side headlight to the chassis, removing the 5th screw completely in the middle. The headlight retainers have level adjusters built into them, so minimizing the bolt turning will ensure you don’t need to have your headlights realigned. Finally, unclip the headlights and remove them.
Step 21: Using a 13mm socket and wrench, loosen the four bolts holding the crash beam to the frame rails. Use a dead blow hammer to punch out the beam.
Step 22: Drain the coolant. Look for the drain plug in-line with one of the coolant hoses in front of the driver’s side wheel. About 2 gallons will come out. Be sure to completely remove the plug for faster draining and open the expansion tank lid for venting:
Step 23: Loosen the outer brackets from the lock carrier to the fender support thing on each side:
Step 24: Unplug this near the driver’s side headlight. Might be for the fans, not sure:
Step 25: Use a small flatblade screwdriver and pop off the two clips that hold the hood release cable to the lock carrier:
Part 2 coming……
