Car is a 2016 A5 coupe S-line. Recently installed a set of Eibach Pro-Kit springs and had it aligned properly. The FTG measurements are: Front- 26 3/8" Rear - 26 1/4" with a full tank of gas, so the rear is just a tiny bit lower than the front. I actually like the ride height and I wouldn't really want to go any lower than, say, 26 1/4" FTG on the front or rear.
So here's the problem---after driving around quite a bit, I don't really like the ride with the Eibachs. Specifically, I don't like the way the car handles bumps at highway speeds. It almost feels bouncy and unsettled. And at low speed, the car seems to react to every road imperfection, no matter how small, much more than with the stock S-line springs. Keep in mind that this isn't my first car with Eibach springs, so I'm familiar with the way a car should normally ride on lowering springs. For whatever reason, I just don't like the way my A5 feels on these Eibachs.
I need to decide on a few different options:
1- Get the Bilstein B8 shocks that are normally packaged as a kit with the Bilstein B12 Pro Kit. From what I understand, just adding those B8 Bilsteins will make a huge difference with the Eibach Pro-Kit springs. But what I don't know is if the ride height will stay exactly the same as it is now. I read that it may not, which I can only assume is because of the height of the spring perch built into the strut.
2- Go with coilovers. My issue here is two-fold. First, I want to avoid a coilover set up that will put my car lower than 26 1/4" FTG at the minimum lowering height. Do any kits allow for "higher" adjustments? My second issue is ride comfort. I've read countless threads here and other forums and it looks like KW has V1 and Street Comfort, but lots of guys complain about noise/knocking or the ride being too soft or too mushy. H&R Street Performance coilovers seem to be a decent option.
3- KW H.A.S. might be an option as well, but I'd still be hesitant to run different springs without also changing out the shocks after my experience with the Eibachs. At that point, I might as well just go with coilovers.
So what should I choose? My goals are simple-- Good ride without being unsettled or overly stiff, lower without being too low, and having the ability to perfectly match the ride height at each corner would also be a huge bonus.
