Results 1 to 7 of 7
    Veteran Member Three Rings fstr n u's Avatar
    Jan 20 2015
    2.5 vs 3 inch exhaust flow tested
    https://www.youtube.com/watch?v=bXQ-cXeri1Y
    Audi members, this was an interesting dyno test of an engine making over 400hp. After the exhaust manifolds/cylinder heads which are the initial exhaust flow restriction, a free flowing 2.5 vs 3" exhaust makes no difference. On a motor like ours even slightly tuned with pulleys,etc, there would be no need for larger than 2.5" exhaust. What people would need to take into consideration would be how well the resonators/mufflers on their exhaust flow.
    Interesting clip.
    2019 Audi SQ5 Navarro Blue Technik w Black Optics Pkg - stock for now
    2015 Audi S4 6MT Glacier White w Black Int (IE Stg 2, Merc Hx, CTS Turbo CAI & CTS S/C Pulley) - my DD
    2006 Subaru STI Hawkeye Murdered Out - larger turbo 400hp - son's car
    1998 Chev Camaro 6MT, LS2 Rear mount Turbo (710+rwhp/710+rwtq @ 14# boost wheels) - summer hooligan
    http://www.youtube.com/@musclecarfan1
    https://www.instagram.com/ryan_baliski/
    https://www.tiktok.com/@winewithryan
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Interesting
    Jan 20 2015
    There is some research that shows over 500hp-600hp crank there are gains to be had with dual 3" exhaust....minimal but some there. The biggest factor is ensuring mufflers/resonators and exhaust tubing diameters ensure relatively free flow. Sound variances come from individual differences in product design.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Too small of piping and it effects exhaust flow. Too big of a pipe and it effects exhaust scavenging. The link below is a video on H-pipes vs X-pipes but it explains what exhaust scavenging is and how too big of exhaust piping can hurt your cars performance.
    https://youtu.be/Dd43rwLHEW4?t=22s
    2016 S6
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    I don't think you would NEED 3" dual, unless you are making closer to 800 HP.
    John Lingenfelter ran 600 plus horsepower Vettes with 2 1/2" exhaust. If bigger would have made him faster, he would have gone bigger. This is further illustrated, when you see the often surprisingly small pipes on pure track cars...which have an almost unlimited budget.
    There is an optimum balance to be found, in volume versus velocity. Basically, you do not want to have a restriction on the volume of air you can move. However, too large of an exhaust will lower the velocity as there will be too great a pressure drop. Additionally, as temperature drops the air molecules become less excited and move slower, further hindering velocity. It is rather complex, but hopefully this is helpful.
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    C'mon, bigger is always better and Audi has known that for years.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Smaller NA motors are impacted even more. Local muffler wizard warned me of this when I was younger. I did not believe him and changed my 2 1/4 pipe to 3 on my 120hp 4 cyl. Holly crap it sounded cool but I lost torque and HP everywhere. Dyno showed it.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
