i'm replacing my coolant expansion tank for the second time (this Vaico only lasted 15,000mi). as with most other issues with this engine, the problem is a lot of heat in a little compartment - namely, that this HDPE tank is a foot over an exhaust manifold. i might try sticking on some heat shield tape, but it's really just a bad place.
i'd love to get rid of the whole damn thing and put an aluminum tank in (well, at least when my finances have stabilized). i haven't run across anything drop-in for B6/B7 S4s, nor have i seen someone fit a generic one.
the stock tank is about 1 liter, has a large outlet and small inlet, and integrates a level switch. has anyone found something that can fit without much drama?
on a related note, my attempts to fix the tank on the cheap have all failed. there are literally only two or three adhesives in existence that will adhere to polyethylene (seriously, go look at all the glues that say "not recommended for PE"), and, for the record, the Loctite Plastics Bonding System will adhere but will not survive coming up to temperature.
- emilio
