Page 18 of 117 FirstFirst ... 816171819202868 ... LastLast
Results 681 to 720 of 4665
  1. #681
    Active Member Two Rings blagarde's Avatar
    Feb 14 2018
    2005 Ducati S4R
    Quote Originally Posted by blagarde View Post
    Hello everyone,
    I just finished installing the new 10.25" head unit in my 2011 S5 cab. After clearing the passenger airbag and parking break faults. Then applying the patch to make the center console go back to life, I can say that I'm pretty happy.
    I have a question though.
    When making a phone call with Bluetooth app I don't seem to be able to hang up. After clicking the green phone icon to dial a number the phone icon never turns red.
    Am I missing anything?
    Thanks.
    Hi guys,
    Do any of you have that issue with the proprietary phone app?
    I also have another issue. If I start backing before Android is fully booted up then go back to a forward gear Android keeps repeatedly switching back to the Audi interface every time I hit the screen. The only way to stop it is to, in the Audi interface, switch the source to something else than aux and switch back.
    Sent from my LG-H918 using Audizine mobile app
  2. #682
    Jan 31 2018
    oakland, ca
    Hi, after installing the new system, i get no sound through AMI port. I put my old screen back in, and still do not get sound through AMI port. Anyone know what is going on and how to fix?
  3. #683
    Jun 22 2017
    St. Louis Area
    Quote Originally Posted by parito View Post
    Did you enable the AUX?
    Sent from my SM-N950U using Audizine mobile app
  4. #684
    Jan 31 2018
    oakland, ca
    i have returned everything to factory setting. unplugged all rsnav cables. put in old screen, and reset vag com codes back to normal. i am using a bluetooth adapter in my AMI port. My phone connects to the bluetooth adapter, and my factory screen shows the songs from my phone, and shows the song being played. but there is no sound coming through. the sd card in my concert radio still plays sound, but the ami port is not playing sound anymore.
  5. #685
    Jan 31 2018
    oakland, ca
    Figured out my issue here. On the factory quadplug (with multiple subconnectors), one of them became loose and the little plastic lock broke off. When we attached the factory quad to the rsnav quad connector, this piece wasn't getting connected since it wasn't locked into place. Got it fixed now, and everything is working smoothly. The system really is great.
    One feedback would be that the Y-Cable that Daniel/RSNav provides could be made smaller. I see how Daniel tried to match the audi factory connector, but if he split his into 2 or 3 components, it would take less room behind the radio, and would be easier to get the radio back in. Also, the quad connector RSNav provides wasn't a very easy fit to the audi connector, so maybe this could be made to be a bit simpler.
    Overall though, the cable harness is done very well. As is the tablet mount, and the overall cabling and connections.
  6. #686
    Feb 16 2018
    WF
    Hi everybody,
    now my console buttons (the two right next to the MMI Button) are blinking. I know, somebody had the same problem, but i didnt find any solution. Maybe this post from Daniel?:
    "So, for the console problem, the problem was identified.
    We designed the serial interface baud rate to be 19200 bps as 3G MMI+(HN+) uses, and it turns out 19200 bps is too fast for BNAV(3G MMI Basic) and HNAV (3G MMI).
    Thus, adjusting bps will make the console work again.
    It seems like we need to differentiate firmware for BNAV, Hnav from HN+, also have to check if the baud rate setting is updatable via software.
    I do not know if we have to replace the affected items yet since I myself did not see the code for the console communication.
    Thanks to Yury for head up on this. "
    I am really afraid, that something is broken.
    THX for help ;-)
  7. #687
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    The issue has been resolved. What MMI version do you have? I am worrying if you updated to 3G MMI firmware while you have 3G MMI+.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  8. #688
    Feb 16 2018
    WF
    No, i did no update. I have the MMI 3G+ with the firmware as delivered. Only installed. But 3 cables are not clear for what they are. First one the black one for the original display and two small (male/female) plugs named "front dash speaker". Maybe this causes problems?
  9. #689
    Feb 16 2018
    WF
    Please tell me how i can solve this, please.
  10. #690
    Jan 18 2012
    Ontario, Canada
    My sq5 also had those two buttons blinking. BUT mine did stop and no longer do it. They seem to blink every time the mmi control unit is removed from the dash... once it’s all put back and the ignition has cycled a couple times the blinking buttons are now gone.
  11. #691
    Feb 16 2018
    WF
    Lucky guy😉
  12. #692
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by MarcWF View Post
    Lucky guy
    Just shipped the flasher board by air envelope.
    Btw, what's wrong with your sound? Still no sound?
    Daniel Kim
    2012 A7 C7
  13. #693
    Feb 19 2018
    uk
    Hi everyone im new to the forum and what brought me here is this item. Im just wondering a few things.
    1. Does this fit a right hand drive car (UK Car)
    2. if so will it fit a 2010 A5 with a 2g mmi system ( no nav or audio bluetooth with controls on the dash not near the gear stick)
    3. If yes to these two questions what else will i need apart from the unit it’s self so i have the gps working and also apple play.
    Thank you to anyone who takes the time to asnwer my questions !
  14. #694
    Dec 23 2017
    Florida
    https://youtu.be/RwDC4s9rQlk
    Scrolling through YouTube and saw this 🤩🤩
  15. #695
    Jan 24 2018
    MD
    Quote Originally Posted by elscotto80 View Post
    I got you fam.
    Looks like it was a white with black striped wire. You can easily test it by putting in reverse and checking the voltage. Also included my relay setup. There were plenty of available fuses in the trunk.
    Sent from my Pixel using Tapatalk
    Thanks much appreciated. Just got everything hooked up over the weekend. Black and White striped wire was the winner on the tester. It was a nice sanity check to see someone else's setup.
    Sent from my Pixel 2 using Tapatalk
  16. #696
    Feb 16 2018
    WF
    wow, great. I need this! Shop?
  17. #697
    Feb 16 2018
    WF
    I ment the touchpad, sorry, no post reply function here in this board.
    The sound is great now. Daniel, with your small hint about the AMI adapter it works now.
  18. #698
    Feb 16 2018
    WF
    But i still need a tip for my blinking console.
  19. #699
    Established Member Two Rings pabohoney1's Avatar
    May 03 2017
    Phoenix
    Do the buttons blink when the car is running or just when it's off? Mine blink when the car if off (I couldn't tell you exactly what circumstances cause it) but I don't think it's really a big deal, it's not hurting anything and it certainly won't drain your battery.
    2013 S4 S-tronic, Merc Racing Heat Exchanger, GIAC Stage 1/TCU, DIY Arduino ECA
  20. #700
    Nov 15 2017
    TX
    Quote Originally Posted by pabohoney1 View Post
    Ditto. Mine blink when the car is off. Not an issue as far as I'm concerned.
  21. #701
    Dec 23 2017
    Florida
    Something I noticed and not sure if this is a bug or not. But when adjusting volume on the steering wheel vs the knob, there appears to be a disconnect between the two.
    For example. using the knob, the audio volume is visible on android screen. Using the knob nothing shows up but the audio still increases or decreases. Overall the knob behaves like a amp controller increasing the maximum audio value based off the last input of the steering wheel volume.
  22. #702
    Dec 01 2011
    Quote Originally Posted by tekkai View Post
    yes same here, its just how it is i guess since it kind of runs like an aux off of it. doesnt really bother me as long as volume adjustment works, i dont really care for the bar itself.
    IG @theshawon
  23. #703
    Feb 11 2018
    Sweden
    Quote Originally Posted by a4android View Post
    What about the BNAVI version of the software patch?
  24. #704
    Jun 08 2015
    Montreal, QC
    This is normal.
    The steering wheel is connected to Android & sound system. So, it changes both Android output value and amp volume value. The radio knob is just changing the amp volume value.
    The best practice for optimal sound quality is to increase the bar to the max so that android output is at maximum and control with radio knob to reduce the amplification by Audi amp.
    Contrarily if you set too low value for Android, and use too much amp volume then high gains from the audio lines will cause noises to be amplified as well.
    Daniel Kim
    2012 A7 C7
  25. #705
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by Prezes View Post
    We didn't receive BNAV unit we bought from the UK. Once it arrives it will be fixed almost immediately.
    I see the unit is in China now.
    Daniel Kim
    2012 A7 C7
  26. #706
    Feb 19 2018
    Ottawa
    Hey there Guys, new to this forum. I've been reading for a long time.. I don't have the 10.25 screen but I bought the 10.1 from Daniel for my 2010 a4. I love it!!! I didn't do the VAGCOM because when I turned everything on the sound worked.. For the Am/Fm and cd. now the only thing is when I try BT music I get no sound or when I put a usb stick with movies I get picture but no sound. When I go into APPS the first AUX says im connected then I have 2 more AUX's in there that say no input when I click on them.. to fix my issue do I still have to do VAGCOM even though my other sound works? Thanks guys. PS. kuddos to Daniel. These units are incredible!
  27. #707
    Jun 08 2015
    Montreal, QC
    Hi!
    That's exactly what's happening if you didn do the coding... or buy an optional noise isolator if you don't want to buy expensive coding kit.
    I think I will have extra noise isolator wires by the end of the month in Canada.
    Daniel Kim
    2012 A7 C7
  28. #708
    Feb 19 2018
    Ottawa
    Hi!
    I have the VAGCOM cable and program. So all I have to do is enable AUX and that will fix my problem?. And how much is that nois isolator?
  29. #709
    Feb 19 2018
    uk
    Hi Daniel , could you answer a few burning questions please.
    few things.
    Thank you
  30. #710
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by ScottyB666 View Post
    few things.
    Thank you
    1. NO
    2. NO
    3. Nothing we can offer.
    ...would it be very sad if i said so?
    But really, for now, that's reality.
    Nevertheless, 2G MMI model line is expected by coming May. Once the mainboard is done, almost every model can be adapted. This means that there will be at least 7" 2G MMI model for UK sometime before this summer.
    Also, we are considering to offer 10.25" for RHD world, but chance is still too low. May be at least i will try to get some drawing so that handy people do it themselves using 3d printer and stuff.
    So this is it. Let's see what we can do.
    Daniel Kim
    2012 A7 C7
  31. #711
    Feb 19 2018
    uk
    1. NO
    2. NO
    Ok thank you for your reply guess ill just have to check again around Summer time if theres a 10.25” for uk model cars. Fingers and toes crossed 😅
  32. #712
    Feb 16 2018
    WF
    Does anybody have problems with his simcard? I installed the card under the sd slot, but the device (10,25) shows me "no sim card". I tried resets, in and out of the card, but nothing happens. THX for help.
  33. #713
    Feb 16 2018
    WF
    Now i tried 3 cards. No function😥
  34. #714
    Jun 08 2015
    Montreal, QC
    Check wifi for sim card direction.
    It's on the usage tips.
    Daniel Kim
    2012 A7 C7
  35. #715
    Feb 16 2018
    WF
    where? on your page?
  36. #716
    Feb 19 2018
    Ottawa
    I tried VAGCOM and in the program it says it dosent read any of my ports. My cable is plugged in fine lights up. And my laptop knows there's a USB plugged. Just in the options section where I have to test the port it dosent read. Am I doing something wrong here? My brother Inlaw is a mechanic. Would any of his code machines be able to enable AUX? Sorry but I don't know much about this stuff
  37. #717
    Dec 01 2011
    i believe he meant wiki not wifi. it's here - http://wiki.rsnav.com/Help%3ATips#SIM_Card_direction
    make sure you're putting the SIM card in the proper direction
    IG @theshawon
  38. #718
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by caro8383 View Post
    If you are in Ottawa, I can help you with it ... PM me ...
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  39. #719
    Feb 19 2018
    Ottawa
    Ok I pm'd you
  40. #720
    Jan 09 2018
    GERMANY
    Daniel, when will we get an update for the 10,25" unit like the other ones got?
