Results 1 to 3 of 3
    Oct 24 2017
    Delaware
    2000 Audi a4 Quattro frame specs
    I'm trying to locate some frame dimensions of some sort for my body guy. I have a lightly bent frame that is easily repairable and he asked for specs. Is anyone familiar with these numbers ? Thanks in advance !
    Nov 28 2015
    Flemington, NJ
    Distance between front mounting points of front axle
    a - 813 2mm (32.0 0.08 in.)
    Distance between rear mounting points of front axle
    b - 620 2mm (24.41 0.08 in.)
    Diagonal distance between mounting points of front axle
    c - 901 2mm (35.5 0.08 in.)
    CAUTION: Use measurements only for checking. Exact measurements can only be assured when you use the repair bench together with the right fixtures.
    Nov 28 2015
    Flemington, NJ
    Distance between front side members
    a - 820 2mm (32.3 0.08 in.)
    b - 1400 2mm (55.12 0.08 in.)
    Distance between fender mounting points
    c - 1310 2mm (51.6 0.08 in.)
    Diagonal distance between hinge mounts and fender mounting points
    d - 1575 2mm (62.0 0.08 in.)
    Distance between outer mounting points of suspension struts
    e - 1028 2mm (40.5 0.08 in.)
    CAUTION: Use measurement - e - only for checking. Correct dimensions can only be assured when you use the repair bench and the right fixtures.
