Results 1 to 15 of 15
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Firestone good for alignment?
    My Avant needs to be aligned. Firestone offers a lifetime alignment for $200. Are they good enough to align a quattro properly?
    2011 A4 Avant Prestige S-Line
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    FUCK NO!!!!!
    There has been alot of threads about members taking their car to Firestone only to end up taking it to the dealer to have it fixed properly.
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Depends on the firestone you go to. Some have good employees that know what theyre doing. But generally i wouldnt take it there. Lol
    Sent from my SM-G950U1 using Tapatalk
    2013 S5 Prestige
    STOCK. for now.....
    Gone: 2010 A4
    Mods: apikol rear diff mount / Zubehör rear diffuser / Unitronic HFC and DP / solo werks / awe boost gauge / carbonio APR intake
    Repairs done: Engine removed to complete repair Piston rings replaced (stage 1 and stage 2 oil consumption fix) / Wheel bearing(s)/hub(s) replaced / Crankshaft pulley/balancer replaced / Timing chain tensioner update
    Feb 24 2004
    Minneapolis
    On my 8th Audi now. First thing I do is buy a lifetime alignment at Firestone. Are they good? How would I know. Is the alignment from the dealer better? How would I know. What I do know is that I get aligned after any suspension work I do, and I don't get weird feathering or shoulder wear or tread noise from my tires. That's all I'm after.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by JayDog747 View Post
    FUCK NO!!!!!
    What do/can they mess up?
    Aug 04 2010
    Queenz/Westchester
    a lot of them dont calibrate their machines. I've used Firestone in the past but after my experience with them I have ended up with uneven wear. But like someone mentioned, every one is different so the one near you may calibrate their machine once a week like they should, in which case it would be ok. Also depending on how low you you are they may never be able to match factory specs without buying adjustable UCAs, and they may charge extra the first time they have to adjust it . I normally get an alignment once or maybe twice a year at most. It's worth it to me to have it done by someone I trust , and I don't trust any of the firestones around me, not just because of their alignment, but i don't trust that they wont scratch my wheels doing something. Also depending on how busy they are, you may have to leave your car there and come back a few hours later to pick it up. A good way to combat that is get there but early in the morning.
    Jul 02 2017
    Knoxville TN
    I've used them in the past with my other cars but I didn't know if a quattro was more difficult to align
    Mar 12 2017
    N.C. USA
    Recommend chkg w/ indy shops & find out who they recommend. Locally several indies recommend the same shop who has a guy in his 60's who has been doing this for over 40 yrs. I happen to have an appointment for tomorrow morning. Another good thing. Only $59.95 for a 4wh alignment.
    PS This man is familiar w/Audi Quattro tire problems. He even personally road tests after aligning & tweaks if necessary.
    2020 Q5 prem plus Matador red/Beige
    Apr 01 2005
    one wagon one truck
    Michigan
    I've used them and never had any issues.
    2009 Audi A4 avant, ECS CAI, Malone stage 2 tune, etc.
    1995 Mazda Miata Montego blue with tan
    2003 A4 1.8tqms Mototec Cold air intake, USP door Blades, GIAC software and bigger injectors. - Gone
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Firestone near me is awful, they adjust tie rods, and thats it. When you ask them to do a 4 wheel alignment they just tell you your car cant have the rear adjusted. Next time around ill be taking my car to audi.
    Feb 24 2004
    Minneapolis
    ^^^^Yep. That Firestone sucks^^^^
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Like said above it all depends on the firestone and the employees they have are idiots or have half a brain. i have a tires plus right next to my place and my audi has never had problem luckily the one right next to my shop is cool, but the only thing i let them do are tires, rotationsa and alignment, and i never let them test drive my car when their done. Check tires plus cuz they are same as firestone maybe would give u more options for finding a shop with decent techs.
    Sent from my SM-G935T using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Senior Member Three Rings DetRebel's Avatar
    Mar 20 2017
    Chevy Trailblazer (the real daily driver); previous car: '11 Brilliant Black B8 A4
    Detroit
    I debated on getting an alignment from an indy shop earlier this year but ultimately decided to go with the dealership. Drop it off on a Friday and get a loaner B9 for the weekend. That will make up for the price difference.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    dropped my car off at firestone this morning and picking up this afternoon.
    im still trying to decide if i pay the 200 (found a 20 off coupon) or one time at 90bucks...
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jul 02 2017
    Knoxville TN
    I did the lifetime
