Results 1 to 13 of 13
    Veteran Member Three Rings swizzchard's Avatar
    Jul 28 2005
    05 B6 A4 1.8TQM USP
    Ellicott City, MD
    Aftermarket Exhaust hot v. cold expansion
    Do all aftermarket exhaust expand to about an inch more in the tips when hot? I've seen/heard this happening on milltek, wondering if it happens on APR, Borla, Etc.
    Also, does anyone know which exhaust will provide low-mid range power. I heard/read that the milltek is more for the upper end. Will any of the quieter ones provide low-midrange power?
    Thanks,
    Searching didnt give me my info
    03 A4 Avant, 85 ABA Golf
    Palo Alto, Ca
    My custom Labree exhaust expanded a little when i first got it, but not anymore.. My right tip (when looking at the back of the car) expanded to the right about 2" and melted my rear bumper
    Never had it expand out towards the rear of the car thou..
    Its comon for all exhausts to expand and contract when heated up at first and sometimes they dont do it at all..
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    my thermal exhaust expands like you mentioned
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    Feb 25 2004
    02 A4 1.8t BT / 03.5 M3
    B-more, MD
    neuspeed. yes
    02 A4 1.8T fwd
    Maestro tuned and built by RAI.... bottom end, some head work, 3071 for now, custom RAI FMIC, and bunch of other stuff that I gotta find receipts for.
    my gallery
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    All exhausts expand when they get heated. Hot metal expands and when it cools it contracts.
    My Milltek is installed in such a way it is flush with the bumper when cold and protrudes just over an inch when hot.
    Palo Alto, Ca
    All the time thou? Or just a few times when it was new?
    Jun 11 2005
    Vancouver, BC
    It expands like that all the time since I've owned it but I have to have had the car running long enough to heat up the exhaust.
    On short trips there isn't much of an extension... maybe 1/4" to 1/2"
    Palo Alto, Ca
    Crazy
    Jul 28 2005
    05 B6 A4 1.8TQM USP
    Ellicott City, MD
    low/midrange power
    no clues on the low to midrange power?
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    I havent noticed it much on my Thermal but then again, I never thought to stare at my tips before and after driving.
    When it comes to power, more than likely as with any exhaust for any car, the louder it is (because of a more open flow design) the more power you will gain. The quieter (more restricted to keep the sound down) the less you will gain. Just basic logic. Then again, if you have it too open like a 4" straight pipe all the way through, youll just lose power because you need some backpressure. And a ricer fart can is just a tip, loud but no power.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Sep 02 2005
    Montreal
    Re: Aftermarket Exhaust hot v. cold expansion
    Thermal Street.
    Jul 21 2005
    MN
    APR exhaust grows about the same.
    Registered Member Two Rings 099-RBN's Avatar
    Mar 05 2004
    2003 A4 Avant
    There are specific measuring points to adjust the exhaust system supports to when the exhaust is being installed, so that as it expands with warmup to operating temps, the exhaust system tubing and the exhaust system supports will not be placed under stress and strained during operation. See Bentley.
