Hello Everyone,
I've been having a coolant leak over the past month and have been trying to identify where it is coming from on my 2004 B6 A4 1.8T. It started about a month ago after I'd come home and leave (few hours later) I'd find a small coolant puddle on my garage floor:
https://imgur.com/a/SK7gv
Background:
I took the car to the independent mechanic here in town and he also is having trouble tracing where the leak is coming from. He put 20 or so PSI on the coolant system, and let it go for 10-15 mins to see if he could spot where the leak was coming from. Unfortunately, he said he was unable to trace the leak. He checked the usual spots (thermostat, oil cooler, water pump, Jplug, etc.) and the ONLY thing he mentioned was he saw some pink crustiness on the bottom of the coolant flange. There is no dried coolant 'vomit' on the back of the engine, where a usual coolant flange leaks, so again I'm not sure how accurate that the flange is leaking to be honest. Also, a lot of those components have been replaced in the last year and should not be leaking (specifically: Thermostat, J-Plug, CTS, Radiator).
Possible Cause:
Since it seems to only leak when things are 'cooling down', I'm not sure if that means it's an o-ring or plastic piece that is possibly shrinking as things cool down. When the car is on and the coolant system is under load, the o-ring is working as expected, and it starts leaking when things are cooling down and the car is off. That is the only thing I can come up with that would make sense, but the question still is where is it coming from. But, hey I could be completely wrong and it is something else that is the root-cause of this coolant leak as well.
Any ideas on possible weak points on where my coolant leak is coming from would be greatly appreciated. If anyone needs any additional information to help in the troubleshooting process, please let me know!
Thanks,
Asif
