Another light issue and after much research it appears that the following code is likely due to bad wiring in the headlight assembly. I pulled the light and so far i am not seeing any bad wiring. It was suggested that I trace the wires from the headlight control module which is on the assembly. And trace the wires to the range control module, which I am told is on the right side of the dash above the glove box. How does one get at this? And I am not finding anything specific on the error code which I was hoping would give me a better direction. Anyone seen this code?
Gosh these headlight assemblies are expensive!
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000016
Shop #: WSC 02325 785 00200
VCID: 699A5B61409CAB0E3D-803C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02626 - Dynamic Cornering Light Motor; Right (V319)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 2
Mileage: 123342 km
Time Indication: 0
Date: 2017.10.31
Time: 22:12:32
