Results 1 to 6 of 6
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    driver side kick panel removal
    Is there a DIY on how to remove this? I understand from reading if you are not careful, you can break the hood release lever.
    I've searched, haven't found anything
    BMW M850i
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I tried searching for kick panel removal and the only thing I was able to find was a really useful tutorial on how to resolve a stuck hood release lever. Now if that is the problem you're having with your car, then this should be most helpful. It doesn't address removal of the kick panel though. I also found a thread about replacing a broken release lever behind the kick panel. It includes a pic of the broken lever with the panel removed, along with the lever bracket part number. Perhaps that will be useful to you.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 21 2017
    I simply need to get the kick panel off so I can stash a speaker crossover unit behind it
    BMW M850i
    Jul 18 2010
    NE Ohio
    Should be similar to removal on a VW as illustrated here ...
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Lol it's easy. Just pull up..
    However, the tricky part is removing the hood latch first. Insert a small screw driver near the round part of the handle. There is a plastic piece that pops out. Once you do that the handle just pulls out towards the passenger side. You may have to lift (open) the handle to get it to come out of the panel.
    Sent from my MI MIX using Tapatalk
    Aug 21 2017
    Thanks guys....
    I was looking for the proper way to pop the hood lever off.....that video shows it
    BMW M850i
