Looking for some advice or direction to be pointed in on potential engine rebuild or engine replacement options for my RS4.
About the car: 64k miles on the ODO. Last carbon clean was done ~14k miles and 2 years ago. I've basically been tracking it for the past 1.5 years with ~15 HPDE track days and the occasional weekend drive. Performance mods can be found in my sig.
Back story: I was at an HPDE day at Sonoma raceway, and I noticed smoke billowing out from the the passenger side under heavy braking. Initially I thought I had glazed over my brakes (still running street pads). I brought it in and noticed a faint ticking noise coming from the engine bay. I popped the hood and saw a grim sight-- the engine bay splattered in oil around the passenger side. I received no oil pressure or warning lights while driving, and my oil levels were slightly low. I was not able to see where the oil was coming from. Additionally, there was that faint ticking noise that sounded like timing chain tensioner, a faint rod knock, etc. So, those were the two issues that needed solving-- ticking noise and where the oil was coming from. Obviously that ended my track day, and I had it towed to 034motorsport in Fremont where it currently sits.
It turns out that the oil was due to a loose valve cover, so that was an easy diagnosis. However, that didn't really explain the ticking. An oil sample was sent off to Blackstone labs where it shows high readings for the following:
Aluminium: 91 ppm (4 ppm is average). Suspect bearing and piston wear
Iron: 29 ppm (14 ppm is average). Suspect excessive wear to cams, crank, or valvetrain parts.
Tin: 11 ppm (1 ppm is average). Suspect bearing wear
Silicon: 24 ppm (7 ppm is average).
Initial theory: Spun bearing with damage to the head.
Upon removal of the lower oil pan, there is quite a bit of metallic coating which provides visual confirmation of internal damage. This is where the vehicle currently sits and I am now assessing my options going forward.
Options:
1. Further diagnose the extent of the damage and determine what is still salvageable for a possible rebuild. Local machine shops are not experienced with an RS4 motor rebuild and are not comfortable with warrantying it.
2. Purchase Audi warrantied re-manufactured long/short block engine. Reman'd shortblock is ~8k, longblock is 10k.
3. Purchase used RS4 motor. Obviously a gamble and this is not warrantied
4. Sell car as-is and/or part out.
Does anyone have experience with a rebuilding an RS4 motor or purchasing or a reman'd block? I do recall McSuly using an R8 motor but having to
