Results 1 to 22 of 22
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Question Upgrading B8 headlight LED strip
    Has anyone thought about upgrading the LED strip in the B8 headlights?
    For the guys that have cracked open the lenses is the LED strip removable or is it fixed.
    I was thinking about adding a brighter LED strip either over the top of the existing one or in place of it. Wiring will be tricky but I think it is doable.
    EDIT: Since I am getting flamed for asking this question let me explain why. I replaced my headlight bulbs with ones that are color rated at 5000k. As you can see in the pictures below the LED strip is not even close to matching the bulbs. My friend has the same bulbs and the LED strips in his B8.5 headlights match almost perfectly.
    2016 S6
    Senior Member Two Rings VtotheJ's Avatar
    Jan 27 2017
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    LOL
    Sent from my Pixel XL using Tapatalk
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    good thread. at least the ones op listed look to be high quality...(they dont)
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Apr 05 2016
    Portland, OR
    I've seen a couple people do custom headlights but I think you would mostly be on your own.
    I agree it is doable and contrary to the fools above not too ricey depending on how you do it.
    Here are my rice headlights:
    Hopefully, now they will attack me and you can get back on task.
    Geoff
    Nov 06 2013
    ^ Looks like shit.
    OP, if you want to have a whiter looking LED DRLs, you're best bet would be to perhaps buy Ecodes. The ones i've seen in person usually burn whiter, crispier light. A cheaper option would be just don't run a 5000K bulb that burns white.. maybe go 4500K. Those LED strip retro fits never look as good as OEM.
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Quote Originally Posted by whiped View Post
    I have the same headlight setup except my ambers are carbon wrapped (actual carbon). I love them
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    Quote Originally Posted by raudiace4 View Post
    ^ Looks like shit.
    You must be blind...Also, I'm guessing OP wants to keep the 5000k bulbs. Otherwise he would'nt have switched to begin with. If you're not going to be constructive, you can go troll elsewhere.
    OP, I've seen where guys in the S7 forums have just soldered new leds in place of the old ones, and that's probably you're best bet in terms of a clean looking result. I think the led strips will give you trouble when you try and conform them to the shape of the oem strip and end up being more trouble than the soldering would be.
    Sent from my SM-G930VL using Audizine mobile app
    "Big" Mods:
    -APR turboback exhaust w/ gutted HFC
    -Intake
    -Treadstone TR8 intercooler
    -2014 A5 engine to fix the oil issue (REEEEEE)
    -Eurodyne Stage 2 tune (I did it myself. Fingers crossed.)
    Garage:
    2011 Audi A5 2.0T 6 MT
    1978 Dodge W-150 (318 cu. in. V8 w/ 4x4)
    2015 VW GTI SE two door DSG (Wife's)
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Pyromatic177 View Post
    My ambers are wrapped in 3M 4-D Carbon fiber wrap I think... I can't remember exactly what its called, it was the closest I could find to matching the carbon on the rest of my car.
    The rest of the housing is all blacked out.
    Geoff
    Nov 06 2013
    Quote Originally Posted by Jezza View Post
    Not blind, that looks like shit. And LED aftermarket strips never look good. Now, go back to the A5 forums.
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Apr 05 2016
    Portland, OR
    lol, someone is wearing his sassy pants today
    Another picture to appease the haters.
    @OP, there is a thread in the A4 forum I believe about people replacing the LEDs in the lights. That might help give you an idea.
    Geoff
    May 17 2012
    Houston, TX
    OP why are your LEDs more amber looking? All the ones I have seen are bright white. Yours looks like they are standard halogen bulbs and not LED. Maybe just the photo but doesn't look right to me
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by AKPS4 View Post
    I was wondering the same thing.
    SOLD 2015 Daytona Gray S4
    Mar 04 2014
    West Palm Beach, FL
    http://oneightynyc.com/
    Only guys I trust to touch my lights.
    Apr 05 2005
    Tampa, FL
    Thanks for the info. I will search for that thread and give it a look over
    Quote Originally Posted by SteveYem View Post
    I am puzzled as you are why they look so amber. I have done the VAG mod to adjust the DRL brightness and with the headlights off they do look whiter. Is there a different setting for when the headlights are on?
    2016 S6
    Aug 02 2015
    Corning NY
    Quote Originally Posted by RendyR View Post
    True these guys are great. Mine were done by OSS designs and they did a good Jon with great customer service! But even that being said I’d say OneEighty
    My headlights
    https://scontent-lga3-1.xx.fbcdn.net...8d&oe=5AAB0A31
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by AudBoost View Post
    Yes, I believe there is a way in VCDS to adjust the brightness of the LEDS while the HIDs are on. It's been a few years since I did it and I cannot remember how, but I remember on my B8 that I set the LEDs to be at full brightness in both DRL mode as well as to remain at full brightness when the low/high beams were on. Hop over to the ultimate VCDS thread and see if you can find the instructions. I think you're right - when those LEDs run at a dimmer setting they appear to color shift away from white, and it's extra noticeable next to the 5000k rated bulbs.
    Off topic, but which 5000k bulbs did you install, and how is visibility compared to the stock bulbs?
    Apr 05 2005
    Tampa, FL
    I looked through the VCDS thread and didn't see a specific adjustment for when the HID's are on. I tried a few settings that dealt with the DRL's but nothing seemed to work.
    And I have the DAMA bulbs which are actually rated at 5500k. The visibility on dark roads is great. The lights do wash some under street lights but on a dark road they light up everything.
    2016 S6
    Apr 05 2016
    Portland, OR
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3
    Set between 5 and 100
    This is with the headlights on. They are at 100% by default without the headlights on.
    Geoff
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    There's a company that does exactly this. They have switchbacks for the turn signals and then sequential addressing for a nice motion, similar to the b9 turn signals.
    https://youtu.be/eJL-ojTwA1M
    Sent from my MI MIX using Tapatalk
    Senior Member Two Rings Zingrox's Avatar
    Sep 03 2016
    Pennsylvania
    http://www.exledshop.com/exled-custo...ules-copy.html
    For those who want the exact link.
    I was debating on building these for a while, but this seems a bit more slim. Company seems to be Korean and a bit lost in translation at times
    Sent from my SM-G930V using Audizine mobile app
