2.0 Tfsi -05 215000km
I was driving for about 5 minutes in slow speed and the car died immediately. The EPC light illuminated. Everything else (radio, lights etc.) were still on. It cranks but won't start.
I can hear the fuel pump in the rear seat when I turn the ignition on.
I've:
Checked fuses (not sure which ones I should check, but I checked #28 and a few others).
Looked for damage around the ECU and the relays (where the 614's are), not sure how to know if something is damaged though.
I should probably also check the coils/sparkplugs.
What else can I check before I get it towed to a workshop?
Some other info:
My car has been leaking coolant like crazy for the last few weeks (one full tank gets me ~50km before Low Coolant warning), if I hold my hand at the generator sometimes I can feel water drops coming from the belt.
CEL has been on for a while, did a scan a month ago and I have P310B (low fuel pressure). More - https://imgur.com/a/6SMly.
I got a chip tune a month ago.
The car was in workshop in April and fixed a few things (I did not own the car at this point), here are some notes about what was done: "Warning for high fuel pressure, have changed pump, removed tuning. Change oil+filter. Low pressure side (at measure only 5bar but went up to 13bar after a short drive. After changing pump we didn't get more than 3bar, therefore change pressure sensor. change high pressure pump own material"
