tvs1320 - supercharger pulley size
tvs1320 - designed boost levels
Stock fuel pump psi = 1,973(maximum)
tvs1740 - supercharger pulley size
tvs1740 - designed boost levels
Anyone have a source for upgrade their own Hitachi fuel pumps; spring size, bore size, etc?
Anyone done a front side oil service on their supercharger (i.e. - their oil changed); what type of oil did you use?
Anyone running programmed water meth on APR or any other supercharger? I'm thinking offset duel-nozzles in rubber elbow just before entering the throttle body...I don't really want to tap into the supercharger neck or plenum area, but does raise issues with tapping the rubber elbow. The rubber elbow is stiff and believe it can handle tapping just fine. My reasoning for this tap point is because its the supercharger plenum that gets hot which is also where the water cooling and twin vertices are and where the air is just before going in to be burned.
Reason(s):
Looking to machine a smaller front pulley
Looking to run water meth
Looking to custom tune
Any technical info/help would be nice.
Car was last pushing 437awhp
