Results 1 to 6 of 6
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    Any shops produce an WATER-to-AIR intercooler systems for our cars?
    Any shops produce an WATER-to-AIR intercooler systems for our cars? Looking for a kit...willing to to the piping fab work from turbo myself. Just ideally looking for a mounting or bolt in solution for the core, water tank, and pump.
    Apr 03 2016
    Up North
    Never seen one that is specific to our cars, but that is definitely not to say they don't exist.
    My buddy did an air to water setup on his Jetta. I think he got a generic kit from frozenboost.com and did a bit of fabrication to make it work. I'll touch base with him and check what the story was... It was a few years ago so details are foggy.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Thinking about this myself as a compact solution this past week after seeing and reading about the systems in the newer GLA 45 AMG, M3/4,... etc.
    Its gonna pretty much be a custom/generic deal with piping to a tank/pump the rear, wiring for the pump, suitable coolant/antifreeze.
    The main part would be a heat exchanger/intercooler to fit in the OEM location and still be 500-600hp capable without front mounting (if possible).
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    Frozen boost has parts you can use to fab up. Make sure you buy the Bosche pump and not their ghetto fish tank pump. You might want to look into custom making a side mount heat exchanger to go where the SMIC is now. I have not seen one yet that looks like a perfect fit.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Nov 02 2007
    SF Bay Area, CA
    Quote Originally Posted by nynoah View Post
    yeah...that's the idea...i emailed a bunch of core manufacturers but none offer anything in the dimensions that would fit. there was one available, but it only supported 400hp or so. my buddy said he'd love to weld up a kit for me, but without having significant downtime i'd much rather prefer a bolt on affair.
    surprising shops like RAI, Eurocode, etc haven't ever offered a setup for us.
    http://www.frozenboost.com/product_i...68b9260aae839e
    maybe i should buy this and have my buddy fab up mounting tabs? honestly want a core that can support more than 600hp though. i think the frozen boost kits are rated higher than what they actually should be. the same size Spearco Core is rated at 400hp...and that is crank HP.
    SPEARCO AIR-LIQUID CORES
    CORE ONLY PART # CORE A B C FLOW ASSEMBLY CORE SIZE
    THICKNESS HEIGHT LENGTH FLOW RATE IN
    CUBIC FEET/ MIN
    HP RATING
    ASS'Y #
    2-206 2.25" x 4.65" x 7.00" 2.25" 4.65" 7.00" 575 405 2-265
    2-213 3.00" x 4.25" x 8.63" 3.00" 4.25" 8.63" 575 405 2-270
    2-170 4.50" x 9.00" x 10.125" 4.50" 9.00" 10.125" 1000 700 2-230
    2-171 4.50" x 4.50" x 10.125" 4.50" 4.50" 10.125" 570 400 2-231
    2-202 6.00" x 12.00" x 13.51" 6.00" 12.00" 13.51" 1800 1260 2-281
    Oct 29 2005
    10speed
    San Francisco, CA
    Always loved the idea of this, especially if it's built for racing. Low pressure drop, more throttle response, can drop some ice in at the track.
    - Clint
