Results 1 to 16 of 16
    Jun 08 2016
    2007 B7 S4
    RS4 Grille on B7 S4 + JHM 91 Suggestions
    I am a brand new owner to an awesome B7 S4 and I'm looking to get into the tasteful mod world...
    I'd like to swap my S4 Grill and foglights casing for the RS4. Does anyone have some good recommendations on where to buy them? I looked at ECS, but it's over $1000 to do that and I'm not sure that I want to spend that just yet. https://www.ecstuning.com/b-genuine-...853651afvmzkt/
    I'm also looking at doing some performance mods, but not go overboard. I read the sticky about being a new B7 S4 owner and what sort of upgrades you can do, but price was never mentioned. I live in Seattle, WA and we only get 92 octane up here, so a 93 tune seems like a waste as it'll have poor performance on our accessible fuel. Does anyone have experience with a 91 JHM tune? I wanted to know what the cost would be and if I have to modify the exhaust as well. I'm not looking at forking out money hand over foot, so do take that in mind.
    It's currently all stock. Here's my starting point! Let the suggestions rain.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    You won’t be able to find an RS4 grill for less than ECS unless someone is selling used. They simply aren’t manufactured. Also, the fog grills are a no go.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jun 08 2016
    2007 B7 S4
    Quote Originally Posted by james12lucy View Post
    What's the reason that the fog grilles are a no go? They come in that ECS kit.
    Jul 04 2015
    Toronto Ontario
    Different front bumper in the RS4. They won’t even fit the DTM bumper which is similar to the RS4
    Jun 08 2016
    2007 B7 S4
    Gotcha. Will the grille itself just fall into place then?
    Jul 04 2015
    Toronto Ontario
    The RS4/S4S-Line grills are all common sized. They’ll fit across all the above. I have an OEM RS4 grill in my S-Line.
    Established Member Two Rings Koopsdeville's Avatar
    Jul 25 2016
    I know LLTEK sells them. Still not cheap. Last I checked the grille was ~$700
    Sent from my ONEPLUS A5000 using Audizine mobile app
    Jul 25 2016
    Jul 25 2016
    On a side note, if u find someone selling them cheaper, let us know. I know there's a huge market for those rs4 grilles except nobody sells em for some reason
    Feb 08 2006
    99 1.8T Passat, B6 S4 Noggy, RS6 01E Stg II Tune
    Columbia, Md; WPB, Fl
    Feb 29 2016
    Bellevue, Ia
    Do these grills fit on a convertible?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Quote Originally Posted by pchrist View Post
    I don’t believe they do. Cabs are like that weird aunt that always makes family holidays awkward.
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    I was considering the rs4 grill route but as specified other than lltek there aren’t any options. I’ve seen rs4 grills pop up but usually around $400 also in order to do rs4 fogs you have to cut up two good sets of covers and fit the mesh into your s4 fog grills. I ended up going with the blackout s4 grill from ecs.
    Nov 12 2015
    Oregon
    Just add some xylene or toulene to your fuel to achieve 93+ octane..
    Sent from my SM-G550T1 using Audizine mobile app
    My build log
    Jul 05 2016
    Ontario, Canada
    Quote Originally Posted by VinnysS4 View Post
    Tolulene is a better octane booster...
    Nov 12 2015
    Oregon
    Sure...
    Toluene is 115 octAne and xylene is 118. Yes, toulene is used as the main ingredient in octAne boosters, but as far as I'm concerned, for as little as would be needed for a small bump on octane, xylene would be cheeper in the end. Both are $19 a gallon where I live.
    My build log
