Page 29 of 36 FirstFirst ... 192728293031 ... LastLast
Results 1,121 to 1,160 of 1433
  1. #1121
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by carlmuck View Post
    Yes, I'm aware. I was already on the Box version 2018.06.26.1620. I updated to 2018.09.03.1744. Still no joy. All other firmware versions are the latest (not beta).
    I restarted the iPhone. No joy.
    I restarted the RSNav. No joy.
    I deleted the 'AutoBox' profile in Settings->General->CarPlay. No joy, and the phone doesn't even recognize a CarPlay accessory.
    So I really do need some help...
    Sorry, I've got no idea .... before I updated to the latest SW for the AutoBox tonight, I had the same issue. After the update all good.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  2. #1122
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Applied new 3 patches from RSNAV and pushing iNav button on wheel shows "Not used button" in FIS and launches no app.
    Any help?
  3. #1123
    Mar 31 2017
    Spanishtan
    Waze available in Carplay. Along with Google Maps and Maps the options are huge.
    (Anyone knows why "time" is ocasionally framed in red?)
  4. #1124
    Senior Member Three Rings viceroy1976's Avatar
    Jul 11 2011
    2014 Audi A4 allroad quattro 2.0TDI
    Johannesburg/GA/South Afr
    Quote Originally Posted by grabie View Post
    Any help?
    Did you check button assignment setting in settings? Maybe it lost the assignment during the patch process?
    2013 Audi S6
    2013 Audi A5 3.0T coupe quattro s-tronic (S5 wannabe)
    2010 Audi S4 6MT
  5. #1125
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by viceroy1976 View Post
    I did, but no response.
    Thanks for the reply.
    Besides, the boot time is almost 0, but welcome exterior lights are malfunctioning...
    Edit: kit remais powered 24/7...
  6. #1126
    Established Member Two Rings Sharkonholiday3's Avatar
    Dec 26 2017
    Italy
    Grabie can you give the new rom via dropbox or similar?
    Sent from my SM-G950F using Audizine mobile app
  7. #1127
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by Sharkonholiday3 View Post
    Hi Shark. Can´t you download it from RSNAV web? One of the files is 1 Gb... besides, I´m having some problems since last update so you might want to wait for the next one. Daniel just told me he´s working on it.
  8. #1128
    Dec 26 2017
    Italy
    ok grabie, i'll wait.
    rsnav are in maintenance mode....this is why i ask you....
    Currently, all the system software update has been erased. We will upload the latest on the second week of October(ETA)...
  9. #1129
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    RSNAV Android System Software Updates
    PLEASE IDENTIFY YOUR SERIAL NUMBER FIRST, IF YOUR SERIAL NO. CONTAINS NUMERICS 1806(means manufactured IN JUNE, 2018) OR UP IN THE SERIAL NUMBER YOU HAVE VERSION 2.0 OF THE MAIN BOARD. e.g. if your serial no. has 1710 in the digits like below picture, then your unit was made October 2017 and you have 'VERSION 1.0' of the mainboard.
    DO NOT UPDATE WITH WRONG VERSION, RESOLUTION, WRONG REGION, WRONG LTE BAND FIRMWARE. IT WILL BREAK YOUR SYSTEM. CONTACT US IF YOU DO NOT KNOW WHAT
    VERSION AND RESOLUTION YOU HAVE OR WHAT REGION YOU ARE IN. THIS IS THE FIRST SOFTWARE TO UPDATE BEFORE ANY OTHER UPDATE. DO NOT PUT
    UPDATE.ZIP, MCU_UPDATE, CAN_UPDATE FILES IN ONE SD CARD. DELETE ANY PREVIOUS FILE THAT YOU ARE DONE BEFORE YOU BEGIN ANY
    NEW PROCEDURE.
    Instruction
    1. Download firmware file from the link (do not unzip or rename the file).
    2. Copy update.zip to the root of TF(MicroSD) card.
    3. Insert TF(MicroSD) card to the slot of the device
    4. If MX Player launches, exit the program, push out the TF(MicroSD) card and insert it again.
    5. When Software update message is prompted, enter '888666' for the password.
    6. Do not interrupt until the device restarts automatically. Maintain electricity power by running your motor idle.
    Do not operate the device or the vehicle. After a successful update, the device will boot up normally.
    It may reboot 3 or 4 times while updating and it's normal. It may take up to 30 mins to update.
    If SDcard is hard to reach
    First, Put the update.zip file to the USB stick's root.
    Second, Ignore the password window, then copy update.zip to the SD card using a file manager app.
    Third, take out and plug in the USB again, then it will show the password window again, input the password 888666
    Finally, take out the USB stick when the system reboots.
    Click here to visit the software update page
    Update Log
    2018.09.28: Added more OBD device support(all classic Bluetooth OBD II devices except BLE devices), improved sound quality(Frequency response range widen) + support volume control on steering wheel in Android, Carinfo app support switching between RHD and LHD mode, improved stability with CarPlay/Android Auto Dongle, Minor bug fixes and patches. Activated 'Hearing Navigation guide voices, Ruixun_BT sounds while in AM/FM Radio and Sat Radio' - For this, if you have 3G MMI supporting models and you must connect centre dash speaker bypass lines to centre dash speaker if you skipped the procedure at your installation.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  10. #1130
    Nov 12 2011
    Singapore
    Hi Daniel,
    I don’t see RSA-70XXX in the latest round of firmware. Only listed for RSA-10XXX, RSB-70XXX
    Can you please confirm?
    Thanks,
    Jasman
  11. #1131
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by soundwave View Post
    Hi Daniel,
    Thanks,
    Jasman
    Rsa-70xxx is rsa-7 now. 1024*600 version 1.0 board.
    Daniel Kim
    2012 A7 C7
  12. #1132
    Nov 12 2011
    Singapore
    Ah, understand. Thanks for the quick response Daniel! I’ll start downloading...
    Quote Originally Posted by a4android View Post
  13. #1133
    Mar 31 2017
    Spanishtan
    Problem solved thanks to Daniel´s instructions. I had to:
    - Disconnect the kit (you just need to remove radio fuse which is the third one from the botton in the right column in the copilot compartment).
    - Apply new patch for Canbus software: "RSNAV ANDROID SYSTEM CAN BUS Updates(SECOND UDPATE TO DO)
    UPDATE THIS SOFTWARE AGAIN IF YOU HAVE CANBUS RELATED ISSUES SUCH AS LOSING DYNAMIC PARKING GUIDELINE, OEM PARKING SENSOR MALFUNCTION IN RSNAV REAR CAMERA VIEW WITH PARKING SENSORS, OR THE SYSTEM DOES NOT GO OFF AUTOMATICALLY AFTER 10 MINUTES SINCE YOUR CAR IS LOCKED."
    Thanks Daniel!
  14. #1134
    Dec 18 2017
    italy
    Hi Daniel
    I have an audi a4 8.8" display version and I'm trying to do the update with the following file:
    RSA-12 10.25", RSA-8 8.8 inch, 1280x480 Resolution, Region Europe, Korea, Australia, HW VERSION 1.0: SW.VER-09181906
    But after the input of the pin the system reboots and show the following screen:
    And the the system is blocked.
    The only thing I can do is to remove the key and wait for the system shutdown.
    Please can you help me?
    Thanks
    D
  15. #1135
    Established Member Two Rings nelsonlye's Avatar
    Feb 26 2018
    Kuala Lumpur
    Same here for 7". Guess need to wait for Daniel to repair the file.
    Sent from my SM-N950F using Tapatalk
  16. #1136
    Junior Member Two Rings
    Aug 27 2017
    AZ
    +1 for another update stuck at the bootloader. Tried a few times without success.
  17. #1137
    Jun 08 2015
    Montreal, QC
    Sorry.
    Please halt the update.zip method, unless you know how to use sp_flasher tool and clean firmware update.
    I am now on a trip and will go back to my place this sunday. I am without my laptop and no one in the factory work either, so we will be able to fix this later this weekend.
    Thank you for your paitience.
    나의 SM-T830 의 Tapatalk에서 보냄
    Daniel Kim
    2012 A7 C7
  18. #1138
    Dec 30 2011
    South Africa
    Hi Daniel
    I want to go the sp_flasher tool root, but your "Download TOOLS" link on the Wiki doesn't work?
    Can you please let me know what files are in that link or can someone please make them available that have it?
    Edit : Ok I found it from an old download I did a couple of months ago when I tried to root the device...
    But seems that the scatter file is also not valid when you download the recovery file, so don't even bother trying the sp_flash_tool way :(
  19. #1139
    Sep 06 2014
    Ottawa, Canada
    When the devices are in this state, will it help or work to roll back to a previous version?
    I have the previous version of the file for the 10.25" NA model. Will it help others if I am able to provide a link to it in the meantime?
    I have both the August version for ver1.0 of the mainboard, and the earlier September release for the v2.0 mainboard.
  20. #1140
    Nov 27 2017
    Odense
    So I decided to come back to all of this after a while and try out the latest updates. But right after I enter the update password and click "Yes" the device just boots into recovery mode.
    I've tried leaving it therre for a few minutes but nothing happens. There's no way to control the recovery menu (it says to use volume up/down and power buttons, but I guess it doesn't mean the MMI buttons.) Turning the car off and on again, the device does boot back up normally, but there is no update happening.
    I've tried downloading the file again, tried using an otherwise empty SD card, tried renaming Update.zip to update.zip, tried removing and reinserting the card while in the recovery menu, pretty much everything I can think of. Am I missing some intermediate updates, maybe?
    This message pops up very briefly before the recovery menu shows:
  21. #1141
    Jun 19 2018
    UK
    Signature verification failure implies to me there is a problem with download file.
    I would try downloading it again.
    Graham
    Sent from my ANE-LX1 using Tapatalk
  22. #1142
    Jan 03 2013
    Baltimore
    Daniel indicated there are some problems with the latest software updates. I would revert back to whatever you were running until it's resolved.
    Sent from my Pixel using Tapatalk
  23. #1143
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by elscotto80 View Post
    x2
    I had serious issues with my Concert/7" unit (lost wheel control and tablet stayed always on) after last update. Fortunately, Daniel uploaded an "emergency patch" which solved my problems.
  24. #1144
    Nov 27 2017
    Odense
    Quote Originally Posted by blueleggy View Post
    Already tried three times.
  25. #1145
    Nov 27 2017
    Odense
    I guess I'll wait a couple weeks or something. Since the update wouldn't start at least there's no damage to undo.
    Incidentally, does anyone know if there's a way to control the recovery menu, i.e. a way to press the volume up/down and power buttons? Seems like it could come in handy.
  26. #1146
    Dec 30 2011
    South Africa
    Hi Daniel
    I updated to the new patch after it was fixed, but I noticed I'm still not able to enter a passkey when trying to connect to my bluetooth device?
    "2018.08.06: add more OBD II BT device support(now user can enter passkey for BT device), Fixed Autoplay app stability, fixed intermittant blackout problem."
    You demo this on youtube video as well?
    Strange that your app menu and bluetooth menu looks newer then the one currently on my unit (after the update)
    In the demo it shows pressing the plus sign before connecting to the device in order to enter the passkey, but menu doesnt look the same and there's no plus key...
    Can you please advise, this is the function I wait for pain painstakingly every time. And its such a disappointment after you wait for months to not be able to benefit from an update...
  27. #1147
    Nov 12 2011
    Singapore
    Is yours screen 7 inch?
    The “+” button is different for our 7” model. At the top-right corner, click on the classic 3-dots to activate BT pin screen.
    Quote Originally Posted by whity View Post
    Hi Daniel
    Sent from my iPhone using Tapatalk Pro
  28. #1148
    Dec 30 2011
    South Africa
    Yes I have the 7", thanks soundwave. I tried that and its still not working.
    Daniel, I'm trying to connect a iMars BT-005 media remote to the unit
    https://www.amazon.co.uk/iMarsTM-Blu.../dp/B01N3LA7Q8
    So I got pass the bluetooth pin, as soundwave pointed out. Entered no pin but its not pairing, if you pair it to any phone it connects instantly with no pin.
    The flexibility of having the remote able to connecting to the RSNAV brings up so many possibilities. Problem is not all of us have the steering wheel with the additional steering buttons (B8.5 etc) as well as the MMI 3G units.
    There is no way to skip forward and back on media players like PlayerPro or Poweramp, not even with the scroll function.
    The media remote can be used for that and even be remapped to other functions in the car like quick launch of apps or what ever your imagination can think of...
    By using the Multilanguage Keymap Redefiner you can map anything to anything. The only limit is how many buttons you have https://play.google.com/store/apps/d...finer&hl=en_ZA
    Thats the main reason for having an additional bluetooth keyboard/media input to have that flexibility.
    I will even purchase one for you guys if you can make it work, because it doesn't seem to work with this method of pairing currently on the RSNAV unit.
  29. #1149
    Jun 08 2015
    Montreal, QC
    Well we activated BT serial protocole but not HID(human input device) protocole and that's the reason why it's not pairing.
    We can buy that remote and can try to have it work with it over HID protocole.
    The reason supporting each bt stuff is painstaking like this is that normal android BT library does not support audi sink(receiving audio) and call control (HFP) so we have to make everything from scratch.
    Daniel Kim
    2012 A7 C7
  30. #1150
    Dec 30 2011
    South Africa
    I understand Daniel, just trying to show the benefit of doing this. As a lot of people can use this, it will be really difficult to work on all profiles I totally agree.
    You mentioned before that you can get more buttons to work with the MMI 3G units but its going to be difficult to do this with the old pre-face lift models because of all the profiles. This is a perfect solution for this, and the remote is really not expensive and can be sold as a bundle in the long run with your units.
  31. #1151
    Jun 08 2015
    Montreal, QC
    will add that to our list of to do's.
    Daniel Kim
    2012 A7 C7
  32. #1152
    Dec 30 2011
    South Africa
    Thanks very much Daniel
  33. #1153
    Dec 26 2017
    Italy
    it is now safe the update dated 18 september for my RSA-7, 10.1(RSA-1020X)", RSB-80XXX, RSB-70XXX, 1024x600 v1?????
  34. #1154
    Apr 12 2013
    spain
    Does anybody have the recovery firmware and tools for 7'' Europe unit?
    The downloads at Developers tools at wiki are broken now.
    Kim will upload tomorrow, but if posible, I need help today.
    Thanks.
  35. #1155
    Jul 11 2011
    +1
    Would also like to know
    2013 Audi S6
    2010 Audi S4 6MT
  36. #1156
    Feb 26 2018
    Kuala Lumpur
    Upgrade failed for 7"
  37. #1157
    Nov 12 2011
    Singapore
    I’ve upgraded the software without issue.
    RSA-7, 10.1(RSA-1020X)", RSB-80XXX, RSB-70XXX, 1024x600 Resolution, Region Europe, Korea, Australia, HW VERSION 1.0: M8.1.0.1.09182152
  38. #1158
    Dec 26 2017
    Italy
    Ok Tomorrow i'll try. Tnx
  39. #1159
    Nov 12 2011
    Singapore
    Audi/Android Interface Units
    I had the latest Sept version updated and the center speaker connected (since Day 1).
    The volume control is a disaster! Perhaps it’s Android’s default, but it’s very broken. The steering wheel volume roller controls the system volume, alarm, ringer and call volume, depending what’s active. I almost died of shock when the Google Maps voice spoke for the first time. Why?? That’s because I used to set the volume at max for all in Volume Adjust apk. And Android seems to adjust alarm volume by default?!
    Tried to fiddle around without success and fired up Google to look for workarounds. In the meantime I’ve installed this app “Volume Control - Vollynx). It helps to lock the alarm volume, call volume, ringer volume at lowest setting. This help me save my ears.
  40. #1160
    Nov 10 2016
    Melbourne, VIC
    Has anyone ever returned a unit to the factory in China?
    Mine has been sitting on "Customs" in GUANGZHOU since the 21st September ...
