Results 1 to 17 of 17
    Active Member Two Rings JBalls's Avatar
    Aug 26 2017
    Hong Kong/Vancouver
    2010 B8 S4 random heavy steering - Steering pump or fluid issues?
    Hi guys, recently purchased a used 2010 B8 S4 in Ibis White from the original owner - 55,000 Km's and a clean history.
    One thing i've noticed recently, and did not pick up on previous test drives, is that during some low speed gradual turns - say from 40-50km/h - the steering will tighten up considerably and gain weight, as if speed sensitive/adaptive steering is kicking in prematurely. It comes on in a hurry and it's pretty annoying when driving normally around town. There's no particular sound or vibration from the steering rack either.
    I've researched online and found some people pointing to steering fluid needing to be topped up, to steering pumps or racks needing to be replaced. Is the culprit difficult to ID? Would my best bet just to be to take to a shop/dealer to get it analyzed?
    Aug 26 2017
    Hong Kong/Vancouver
    Bump - Any ideas for solutions appreciated.
    Jul 14 2013
    British Columbia, Canada
    Do you have audi drive select so you can choose between comfort, auto, and dynamic? If you don't it may just be the auto setting doing its thing. You can use VAG-COM to set the car to comfort and see if there is any difference but I would start with that.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Aug 26 2017
    Hong Kong/Vancouver
    Quote Originally Posted by B8Addict View Post
    Nope i don't have Audi Drive Select. Would have been nice if it was that simple.
    Audi S4 B8 | Ibis White | Magma | Carbon Atlas | B&O | Michelin Pilot Sport 4S | AG M590 | Bilstein | H&R
    Jul 14 2013
    Quote Originally Posted by JBalls View Post
    It likely is the auto setting at this point as it will continue to vary as you increase in speed. Since you don’t have drive select you can’t change it without VAG-COM.
    May 06 2004
    W124s
    PA
    Usually occurs differently than you've described, but you may check the steering column intermediate shaft u joint near the rack. Common part that binds causing tight steering, may be noticeable if you turn the wheel lock to lock and notice binding at a few parts in between.
    Keep right pass left, it's the law!!
    Aug 26 2017
    Hong Kong/Vancouver
    Hmm i appreciate the suggestion it may be related to some auto setting, but the way the steering weight increases just doesn't feel really natural, like there's no way Audi could have a setting to make the car steer like this on purpose. Through a low speed turn anywhere from 20-40km/s it will begin to tighten up unnaturally, and stay tight even as i begin to deccelerate...
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by quickglx View Post
    This has been the problem on 3 different S4's I've worked on.
    Sprayed some lube on the U joint a few times and good to go.
    Sent from my SM-G920W8 using Audizine mobile app
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    pics of location to lube?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Aug 26 2017
    Hong Kong/Vancouver
    Quote Originally Posted by s4matty View Post
    Thanks, that's interesting, I'll ask my shop to take a look at the U Joint, would love for it to be as simple as that.
    Aug 17 2015
    bump for pics or diagram of where to lube?
    C7.5 S6
    B8 A4
    Veteran Member Three Rings ToddBrunswick's Avatar
    Dec 07 2015
    PorscheCayenne
    Culver City, CA
    Quote Originally Posted by IHave2Turbos View Post
    That's some low hanging fruit.
    Pedal Responce Consigliere
    "I have a special practice. I handle one client" -Tom Hagen
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    Is this something that’s easily accessible and what kind of lube? Pics or a link would help some of us out with this issue.
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by EAFLO88 View Post
    I'll post a pic where the joint is tmrw when my friends car is on the hoist.
    As for the lube I used was castle trust..
    Kinda like wd40 but with a lube in it.
    I sprayed the joint and turned the steering wheel back and forth a few time s then sprayed again..
    But I'll post the pics tmrw.
    I just had to do my cars steering joint last week also.
    Big difference after.
    Sent from my SM-G930W8 using Audizine mobile app
    Aug 26 2017
    Hong Kong/Vancouver
    I forgot about this thread.
    I still haven’t had the U joint looked at regarding the heavy steering issues, but interestingly, since I’ve upgraded my wheel setup (AG M590, MPS4S, alignment) from stock OEM, the steerings been lighter. Not to where I would say there’s no more issue, but it’s more bearable.
    @s4matty - I’m interested in that photo too. Thanks.
    Dec 08 2016
    Texas
    Thanks for the insight, looking forward to the picture
    Jul 16 2017
    2015 Audi A4 B8.5
    Staten Island/New York
    picture please
