Searched but didn't see much for a DIY or anything recently.
I'm in the midwest so there is salt on the roads. I know the pinch bolt is going to be the hardest thing based on research. Been spraying it with penetrating oil for a couple days. Looking to find some time to replace the whole kit and kaboodle. Bought a kit from B6Option3 kit from FCP I believe.
I know there are are couple things a person needs to do. Penetrating oil is one of them and torque the nuts once you have the weight of the car on the arms. I plan to take hub to fender measurements and then just jack the hub up to that height while on stands. No way would I be able to reach in there when the car is on the ground.
So couple quick questions. What has it taken you to do this time wise? I'm just a shadetree wrencher and work on my own stuff. I just want to know if its a day with a rusty pinch bolt or 4 days (/exaggeration)? Also does a person have to remove the whole upper strut assembly or can they get a box end wrench tucked between the spring and assembly at the top? I assume liberal amounts of antiseize should go on the new pinch bolt during installation?
Lastly do I replace everything? The steering on my USP is still really tight, just the rubber bushings are trashed in the arms. I have almost 200k and to my knowledge none of it's been replaced.
