Results 1 to 19 of 19
Thread: A3 seat options
    Oct 18 2017
    WI
    A3 seat options
    Just bought a new 2017 A3 and love the car but hate the seats, specifically the lack of side bolstering. Im coming from a GTI which had great bolster support.
    Im trying to understand what other seats might be a fairly direct fit (same rails, possible some wiring work)
    So far considering
    S3 seats (tough to find)
    S4 seats (seems like quite a few on ebay)
    TT seats (found a couple possible, but not sure about the fit)
    GTI seats (not sure if they would fit)
    Recaro Sport Topline (expensive and lose the airbag)
    I would greatly appreciate any insight of what might be a good swap.
    Nov 17 2014
    San Francisco, CA
    In the same boat, basically any vag group seat will fit. Seat, skoda, audi vw. Overall audi seats seem to be made for looks and not real spirited driving. Even the sport seats are pretty weak in terms of side bolster support.
    I've been looking at braum and cipher seats, roughly 1k for seat and rails, but you lose airbags and I'm not sure anyone has successfully been able to not have am airbag error light without buying or using existing seat the sensor/relay.
    BRAUM - Pair of Black Leatherette Carbon Fiber Mixed ELITE-X Racing Seats with Blue Stitches (BRR1X-BKBL) https://www.amazon.com/dp/B074DM5QHD..._7Xb6zbGTY04SX
    Cipher AR-9 Revo Racing Seats -Black Leather Carbon Fiber w/ Black Stitches -Pair https://www.amazon.com/dp/B071WDN1NT..._bXb6zbRH49ZEX
    Sent from my SM-N910V using Tapatalk
    May 24 2016
    I hate the seats in my s3 as well. Do you guys know if the air bag light is on if the airbags will not function or if it's just a warning stating that an airbag is missing?
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by jpy1980 View Post
    Light is on, but all other bags work.
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    I bought a set of the regular Braum elites in microsude for the track. Will be installing them in the next couple of weekends. I pulled them out when I rec'd them and they are snug for sure. They will be a light years jump over the Super Sports, which I really like for everyday. also I'll be doing Schroth quick fit pro's and I won't be moving an inch. Can't wait! the microsuede grips your clothing well, that's why I got it.
    2016 Monsoon S3
    My slow build link - Onequick4door
    May 24 2016
    You guys know if these racing seats maker you sit lower?
    Senior Member Two Rings soulflyer's Avatar
    Apr 06 2015
    Ottawa, Canada
    Not much, depends if you use slider rails or fixed ones. I have fixed ones and I am maybe 1inch lower in my Sparco.
    2018 S3 Technik, Ara blue
    SOLD 2015 S3 Technik, Sepang blue
    I have VCDS, will do scans and coding for beer in the Ottawa ON, area. PM me.
    Mar 29 2017
    Philadelphia, PA
    I put Recaro Sport Toplines in my '15 A3. They are defintely expensive, but they're great.
    Your car will need a 2.2 ohm resistor to be installed since the O.E. side impact airbags will be removed with the original seats. Going to need to harvest the yellow airbag connectors from the original seats and solder in the 2.2 ohm resistor between the 2 wires that feed the 12 volt positive and negative to the airbag igniter, the 3rd wire is a ground wire on Audi and VW vehicles. The Passenger Side Occupancy Sensor will need to be harvested from the original seat and custom adapted into the Recaro seat. You also need a relay to be installed with a "Key-On" source as a trigger, so the power is cut to the seats when the key is turned off or removed, since hard wired seats could have the heating or cooling features left on which would drain down the battery.
    The only hiccup during installation was the seat belt bracket. Had to fabricate a piece so that the seat belt bracket would fit, not a big thing.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    its almost been 2 years since ive had my s3, i CANNOT find a comfortable seating position. (standard seats)
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    May 24 2016
    Jeez! Only if you were around So i could pay you to do all that for me! Haha i may just have to live with the light.
    What bracket are you using? I'm planning on getting the planted brackets with the recaro slider. Would those brackets need a fabricated seat belt bracket?
    Mar 29 2017
    Philadelphia, PA
    Haha man if only I could have done that myself, would have saved me big on that labor cost. Here's a list of the parts purchased for the job.
    I'm not sure how optional switching that passenger occupancy sensor is. I'd assume the passenger airbag would never go off if that wasn't harvested from your original seats?
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Quote Originally Posted by extensive View Post
    So I'm clear, your talking about all that electrical rigging for a full time seat swap, correct? I'm just keeping everything unplugged(codes a flyin) and put the stock SS's back in after the track.
    2016 Monsoon S3
    May 24 2016
    I just think the seats and seating position suck in general in the S3. Are there any negative repercussions to having an aftermarket seat and have all the codes remain? Like will something not work besides the missing airbag?
    Nov 17 2014
    San Francisco, CA
    Can anyone share pictures of their aftermarket seats?
    Apr 06 2015
    Ottawa, Canada
    Quote Originally Posted by mroberte View Post
    Here is my detailed DIY...
    http://www.audizine.com/forum/showth...1#post12109857
    The swap takes me about 10min...
    Nov 17 2014
    San Francisco, CA
    Thumbs up Thank you for the seat installation instructions
    Quote Originally Posted by soulflyer View Post
    Wow, thank you for that very informative post with details on the swap. I'm pretty beat up usually after a track day because I'm trying to force myself to stay put in my non-sport seats, so side bolstering and the thigh support is very much needed.
    Feb 16 2004
    Bay Area
    Something to keep in mind. Although the factory seats aren't the greatest, proper seating position that enables proper usage of the shoulder bolsters requires that the seat sits far more upright than one typically expects. Spending time finding the correct angle will make a significant difference. Your shoulders should nearly be digging into the seat. Even with an aftermarket seat, if you aren't seated properly, you won't get the complete benefit. Racers in stock classes that don't allow for upgrades have also added silicone pads to the seat. Throw it on top before you hop in, it adds a great deal of friction that will keep your bottom in place. Coupled with locking the seat belt, which is much easier on manual seats than power seats, a locking clip, or CG lock and you'll have a decent amount of seat attachment.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Yeah I know what you mean about being beaten up. My lower back is a mess for a couple days after an event. I will take pics of my Braums and do review on them.
    2016 Monsoon S3
    Mar 29 2017
    Philadelphia, PA
    Quote Originally Posted by onequick4door View Post
    Yeah. If you're just swapping them in and out on track days you won't have to worry about the wiring. Although if you're getting a track only seat there's better options than a Recaro Sport Topline. I'd probably go for a bucket seat without any wiring if it's solely for the track.
