I read 2-3 threads yesterday that were referencing websites and places that sell GOOD rebuilt heads. AWM
Now, I have been searching for the last 2 hours and I cant find them anymore.
Can you guys help me, please? old_guy and others that bought heads, where did you get them from?
Car has 165k miles, stock, (well, SAI is soft coded out) started with a cold start rough idle and in less than 2 weeks it ended up with no compression AT ALL in cyl 2.
Head is coming out soon. I started today and realized that the head bolts are polydrive, 6 point....pos. I have the 12 point bits that I used on my TDI and didn't even think that this would be different :(
Anyways, I'm curious to see why there is 0 compression in cyl 2. I mean, not even 1 psi. The other 3 where between 140 and 160.
The sparkplug also snapped while taking it out (cyl 2). That was fun. Ended up using a "fix'a'thread" from helicoil. 4 hours of hard cussing:)
Timing was ok. I did it about 20k ago. Because of a leaky water pump. So, that's a bummer. I will end up doing it again since I'm in there. There goes 350$ down the drain.
Snapped the thermostat housing top nipple while removing the coolant hose going to the hard pipe on top of the intake manifold.
Back of the engine coolant flange is leaking heavily.
Damn car. I just put 3000$ in full new suspension and breaks.
And 400$ in tranny fluid and filter refresh.
I swear, sometimes I think it's cheaper to have car payments than keep fixing audis :(
Sorry for the rant, but I have a 2010 avant as well, and a new engine is sitting on the stand waiting to be installed in it. Low oil pressure at idle. And my 06 Subaru Tribeca is misfiring in cyl 6. So I have 3 sick cars right now. I'm gonna drive my John Deere tractor to work tomorrow :)
