Results 1 to 10 of 10
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    Looking for Cam chain replacement DIY
    Can anyone help me find a DIY for replacing the cam chain on a 1.8T? Ive found a lot of cam chain tensioner replacement write ups and videos but nothing specifically for the cam chain itself. My car has about 150K on it and i want to replace both while i have it opened up. Just not sure how hard or easy it is once you get the cam chain tensioner out.
    Thanks for any guidance!
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    If you have a DIY for the tensioner, you're pretty much there with regards to the chain.
    Things to note...the cams have to come out, so you'll have to remove the timing belt. Plenty of DIYs there.
    If you mark the old chain before disassembly, then you can match it with the new chain and mark it.
    The Chilton's manual is pretty good for this except the line up of cam sprockets and chains. I use this diagram and have never gone wrong.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    May 25 2009
    Audis
    Conshohocken, PA
    [QUOTE=egovreau;127145[/QUOTE]
    Gotcha. So the chain should be pretty much self explanatory when i get the cams out.
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
    Sep 08 2015
    Orting, WA
    Quote Originally Posted by Rocs View Post
    Pretty much.
    If you were reusing the old chain, the only stipulation is that you ensure it is installed so it turns in the same direction.
    Once all the bearing caps are removed, and the tensioner is free, you can grab a cam in each hand and lift everything out.
    Established Member Two Rings SO WAGN's Avatar
    May 17 2015
    B6 A4 S Line Stage 3+ E85
    Australia
    As stated in many other threads, if you have the cam chain tensioner tool (screws into frame of the CCT and pulls down on the top CCT pad to take away the spring load pressure), you don't need to remove the exhaust cam. This means you don't need to muck around with the timing belt at all.
    Some people are able to squeeze out the CCT without completely removing the intake cam but it would be mighty tricky IMO. I've done my CCT a few times and each time I've removed the intake cam completely and then loosened the cam caps on the exhaust cam just enough to get the wiggle room to get the CCT out. That way i never lost contact of the timing belt to the cam gear.
    The only reason I would take out the exhaust cam completely would be if I was changing the timing belt as well, also giving the opportunity to change over the cam seals (can't change the exhaust cam seal without removing the cam gear).
    Another piece of advice, don't over tension the CCT removal tool, I did and broke the damn thing so had to order another.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by SO WAGN View Post
    agree with all this
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jun 26 2015
    Tampa, FL
    The real question though is why are you replacing either?
    Senior Member Two Rings jquattro's Avatar
    Oct 15 2011
    02_A4_1.8TQMS
    Oregon
    Here is a video that might help.
    https://www.youtube.com/watch?v=zFOqW0x7oiI
    '15 S5 6MT
    May 25 2009
    Audis
    Conshohocken, PA
    I bought a AMU head after the timing belt snapped on my car. SO i a doing a while timing belt job and was told i should replace the CCT on this AMU head. I guess i could just change the guides and keep the OEM CCT?
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
    Jun 26 2015
    Tampa, FL
    Keep the OEM CCT (or use the one from the old head.) Change the shoes. I guess change the chain if you really want. You'll want to loosen all the cam caps anyway to make sure they're torqued correctly.
