Results 1 to 12 of 12
    Veteran Member Three Rings TwoSnelz's Avatar
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Help Me Identify Warning Symbol
    I had my center display show me this symbol. Could not find anything that seems to match it in the manual or around online.
    The bad pixels don't make it any easier. Anyone know what this means? Light went away after I restarted the car.
    Sent from my XT1254 using Audizine mobile app
    Sep 19 2012
    Saint Clair Shores MI
    My guess...
    But I would grab vagcom to be sure. If you don't have vagcom.. Get it. Scout the forms to get it cheap. You'll thank yourself a million times over if you plan on keeping the b5
    Sent from my SM-G930P using Tapatalk
    Sep 09 2014
    Grand Rapids, Michigan
    That's the symbol for a light being out. Basically looks like this: (x). Vcds will not show cluster warnings by the way.
    Sep 19 2012
    Can't you list the active warnings in there? I could have sworn I've done that.
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    Have vagcom, light went out! It looks like it has text near the top. Says maybe tcm or icm? I have a manual transmission however.
    Aug 04 2013
    Pennsylvania
    I think it looks like the low fuel light but I see you have almost a full tank. Or maybe the yellow coolant level light?
    I'm like a tree. I'm all root
    Jun 23 2015
    Michigan
    Quote Originally Posted by Trb1 View Post
    It's this. Upside down light bulb with the X in the center. Bulb out. So could be faulty or old wiring.
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    If it comes back when the car is cold the display works well so maybe I can get a better pic of it. I'm tooling today so I'll check all the bulbs and fluid levels.
    Aug 04 2013
    Pennsylvania
    Hmm... maybe my screen just sucks but it doesn't look at all like the bulb warning to me.
    Now that I know what the bulb out indicator looks like it's obvious, but the first time I saw it all I could think was why is there a turtle on my dash...
    Established Member Two Rings a_brooks86's Avatar
    Jan 20 2016
    2009 Audi A4 P+, 2015 Ford Focus SE Hatchback
    Southeast Missouri
    Bulb failure? Looks like the one that's bottom left on this warning key.
    Sent from my SM-G955U using Audizine mobile app
    2009 A4 2.0T Premium Plus
    - Solo Werks S1 Coilovers
    - 034Motorsport Adjustable Upper Control Arms
    - Michelin Pilot Sport A/S 3+ Tires
    - B8.5 Engine Swap (CPMA)
    - CTS Turbo Kit w/ Test Pipe
    - TR11 Intercooler
    - Eurodyne Maestro w/ K04 tune
    - Snow Performance W/M kit (yet to be installed)
    - Aluminum Charge Pipe kit (yet to be installed)
    Junior Member Two Rings
    Jan 04 2017
    You should send your cluster out to BBA Remanufacturing to fix the display. I had it done on my 2001 TT and they did a great job. They replace everything in the cluster...bulbs, display, tach and Speedo. Mine cost $300, but the guarantee it for life. I lost lines the display a few years later and they fixed it for free. And if memory serves me, they paid shipping.
    Sent from my SM-G950U1 using Audizine mobile app
    Sep 09 2016
    2001.5 Audi S4
    Northeast PA
    I just had a headlight bulb go out tonight, so looking like that was it.
    I want to have my cluster fixed but I've been waiting to go out of town so I can send it away and it will be done by the time I'm back.
    I DD my car so I don't want to have to bum rides to work while it's down.
