Also, to be clear, it's not actually the DV that's making that noise, but it is likely causing it. It's called compressor surge. Here is a good write up about it, what it is, and what it does.
http://www.gfb.com.au/tech/tech-arti...mpressor-surge
If your DV is not making a good connection or plugged in the whole way, you're likely fitting into this paragraph:
"The next level down in severity is having no diverter valve of any type. In this case, the turbo will surge every time the throttle is closed if there is boost pressure in the intercooler. These conditions can cause accelerated turbo bearing wear, however in lightly boosted systems this is unlikely to shorten the turbo’s life a great deal – note that diverter valves were not commonly factory-fitted to turbo cars prior to the early ‘90s, and turbos were still considered to have an acceptable life expectancy. Such turbo systems however were generally running relatively low boost pressures, and it would be fair to say that wear would be greater on a more heavily boosted turbo. The lowest level of severity would be cars fitted with a diverter valve that sometimes encounters surge at lower RPM, before the turbo has fully spooled up. In these cases, wear associated with the surge could be considered negligible - other factors such as increased boost or even differences in driving style are more likely to have a greater impact of the overall life-span of such a turbo than low RPM surge."
