Results 1 to 7 of 7
    Aug 04 2016
    Athens,GA
    Car Battery Replacement
    Well I left my car sitting for 2.5 weeks and now the engine won't turn over. I put my battery to charge for a hour and it starts right up. Next morning, it won't turn over. I looked online and there is like 5-6 batteries with different amp hours. Anyone replaced their car battery before and know what to get?
    S6 2013
    Old battery part # 4G0 915 105 E
    Mar 26 2010
    US
    Quote Originally Posted by averagejoe26 View Post
    S6 2013
    There are a number of options.
    On my B8 S4 I just went to Autozone for the battery.
    Some Audi owners have gone with calling AAA or Audi dealer at a cost of around $200
    This type from Autozone should be fine. $155, Duralast Gold Battery
    Part Number: H8-DLG
    Battery Group Size Designation: 49
    Warranty: 5 years
    Cold Cranking Amps (CCA): 950
    Cranking Amps (CA): 1000
    Reserve Capacity (min): 185
    "Vehicle Fitment, This part fits your vehicle(s):
    2016 Audi S6 Prestige Quattro 4.0L FI Turbo DOHC 8cyl & 409 other Audi vehicles:
    4000 (4)
    5000 (2)
    4000 CS Quattro (1)
    5000 (Can) (2)
    A4 (8)
    A4 Allroad Premium (1)
    A4 Allroad Premium Plus (1)
    A4 Allroad Prestige (1)
    A4 Premium (3)
    A4 Premium Plus (3)
    A4 Premium Plus Quattro (5)
    A4 Premium Quattro (5)
    A4 Premium Quattro (Can) (1)
    A4 Prestige (2)
    A4 Prestige Quattro (3)
    A4 Quattro (11)
    A4 Quattro Avant (3)
    A5 Cabriolet (5)
    A5 Premium Plus Quattro (4)
    A5 Premium Quattro (4)
    A5 Prestige Quattro (2)
    A5 Quattro (10)
    A5 Quattro Cabriolet (7)
    A5 Sport Quattro (2)
    A6 (6)
    A6 Competition Quattro (1)
    A6 Premium (6)
    A6 Premium Plus (6)
    A6 Premium Plus Quattro (11)
    A6 Premium Plus Quattro TDI (3)
    A6 Premium Quattro (7)
    A6 Prestige Quattro (6)
    A6 Prestige Quattro TDI (3)
    A6 Quattro (18)
    A6 Quattro (Can) (2)
    A6 Quattro Avant (2)
    A7 Competition Quattro (1)
    A7 Premium Plus Quattro (3)
    A7 Premium Plus Quattro TDI (2)
    A7 Premium Plus TDI Quattro (1)
    A7 Prestige Quattro (3)
    A7 Prestige Quattro TDI (2)
    A7 Prestige TDI Quattro (1)
    A7 Quattro (3)
    A8 (3)
    A8 L Quattro (11)
    A8 L Sport Quattro (1)
    A8 L TDI Quattro (3)
    A8 L W12 Quattro (5)
    A8 Quattro (24)
    A8 Quattro L (1)
    Allroad Premium Plus Quattro (4)
    Allroad Premium Quattro (4)
    Allroad Prestige Quattro (3)
    Allroad Quattro (4)
    Q5 AWD (1)
    Q5 Hybrid AWD (Can) (1)
    Q5 Hybrid Prestige AWD (4)
    Q5 Premium AWD (6)
    Q5 Premium Plus AWD (11)
    Q5 Premium Plus Quattro (5)
    Q5 Premium Plus S Line Quattro (1)
    Q5 Premium Plus TDI AWD (2)
    Q5 Premium Quattro (2)
    Q5 Prestige AWD (6)
    Q5 Prestige Quattro (3)
    Q5 Prestige S Line Quattro (1)
    Q5 Prestige TDI AWD (2)
    Q7 AWD (10)
    Q7 Premium AWD (6)
    Q7 Premium Plus AWD (6)
    Q7 Prestige AWD (6)
    Q7 Quattro (Can) (1)
    Q7 Sport Quattro (Can) (1)
    Q7 TDI Premium AWD (5)
    Q7 TDI Premium Plus AWD (5)
    Q7 TDI Prestige AWD (5)
    R8 Plus Quattro (1)
    R8 Quattro (1)
    R8 Spyder Quattro (1)
    RS 4 Quattro (2)
    RS 5 (3)
    RS6 Quattro (1)
    RS7 (4)
    RS7 Performance (2)
    S4 Premium Plus Quattro (3)
    S4 Prestige Quattro (3)
    S4 Quattro (10)
    S5 Premium Plus Quattro (3)
    S5 Prestige Quattro (3)
    S5 Quattro (8)
    S5 Quattro Cabriolet (3)
    S6 Premium Plus Quattro (2)
    S6 Prestige Quattro (2)
    S6 Quattro (10)
    S7 Premium Plus Quattro (1)
    S7 Prestige Quattro (1)
    S7 Quattro (4)
    S8 Plus Quattro (1)
    S8 Quattro (7)
    TT Quattro (2)
    TTS Quattro (2)"
    BMW M3 Competition X-drive
    Aug 04 2016
    Athens,GA
    Awesome, thanks
    Jan 07 2014
    United States
    Quote Originally Posted by wwhan View Post
    Part Number: H8-DLG
    Warranty: 5 years
    4000 (4)
    5000 (2)
    4000 CS Quattro (1)
    5000 (Can) (2)
    A4 (8)
    A4 Premium (3)
    A4 Premium Plus (3)
    A4 Prestige (2)
    A4 Quattro (11)
    A5 Cabriolet (5)
    A5 Quattro (10)
    A6 (6)
    A6 Premium (6)
    A6 Premium Plus (6)
    A6 Quattro (18)
    A7 Quattro (3)
    A8 (3)
    A8 L Quattro (11)
    A8 Quattro (24)
    A8 Quattro L (1)
    Allroad Quattro (4)
    Q5 AWD (1)
    Q5 Premium AWD (6)
    Q5 Prestige AWD (6)
    Q7 AWD (10)
    Q7 Premium AWD (6)
    Q7 Prestige AWD (6)
    R8 Plus Quattro (1)
    R8 Quattro (1)
    RS 4 Quattro (2)
    RS 5 (3)
    RS6 Quattro (1)
    RS7 (4)
    RS7 Performance (2)
    S4 Quattro (10)
    S5 Quattro (8)
    S6 Quattro (10)
    S7 Quattro (4)
    S8 Plus Quattro (1)
    S8 Quattro (7)
    TT Quattro (2)
    TTS Quattro (2)"
    Does the battery have to be programmed similar to BMW's ?
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    The battery typically requires coding. The Ross-tech site has good instructions on how to do this.
    Mar 26 2010
    US
    Quote Originally Posted by Kczach View Post
    With a new battery, use a VCDS to just change the last digit in the battery serial number, which will let the controller know, the battery has been changed.
    Mar 26 2010
    US
    http://wiki.ross-tech.com/wiki/index...ry_Replacement
    As noted below, but only need to change the last digit of serial number. The number is not critical, it just needs to change.
    "" 19-CAN Gateway using (UDS/ODX)
    This procedure applies to battery replacement in vehicles using a battery management control module that is a slave/subsystem of the CAN Gateway.
    Address 19: CAN Gateway
    Battery Monitoring Control Module:
    Adaptation
    Installation of a new battery requires the use of the [Adaptation-10] function under 19-CAN-Gateway control module. Use the drop-down menus to enter the Part Number, Vendor, and Serial Number information located on the new battery .
    [Select]
    [19 - CAN-Gateway]
    [Long Adaptation-0A]
    Battery adaptation - Size
    Select the battery Ah rating from the drop-down menu followed by [Do It!] and confirm [Yes]
    Battery adaptation - Manufacturer
    Select the battery manufacturer from the drop-down menu followed by [Do It!] and confirm [Yes]
    Battery adaptation - Serial number
    Type the serial number code from the replacement battery followed by [Do It!] and confirm [Yes]
    Providing the value was accepted by the controller the new battery coding is complete.
    [Done, Go Back]
    [Close Controller, Go Back - 06]"
