Results 1 to 40 of 53
    Senior Member Two Rings jester7677's Avatar
    Mar 24 2007
    NH
    TTS wheel fitment and info...
    I didn't want to pollute the RS thread, so ... If folks could share the specs and wheels they know will fit and/or what they had to do to make them fit, that would be super. I'm in the market for 19" and all season tires for the winter. I work from home so I can get way with All Seasons.
    2018 Audi SQ5
    2017 Audi TTS (gone)
    2004 Audi S4 (gone)
    2000 Audi S4 (gone)
    Veteran Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    18x9 et45 265\35
    19x9 et45 265/30
    2016 TTS
    Mar 24 2007
    NH
    Looking for rims to run all seasons for 6mo out of the year here in the Northeast.
    I see your going with ET 45. I'm not well versed in wheels so if this is a dumb question, feel free to correct me... but I was thinking 19" ET35 to try and get them as flush as possible without sticking out. I don't know what the stock 20" Black Optics rims are... maybe I need to figure that out first.
    Also, what do people do with the TPMS sensors if they have 2 wheel sets?
    2018 Audi SQ5
    2004 Audi S4 (gone)
    2000 Audi S4 (gone)
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    I prefer 18" for Winter as taller sidewall to help with pothole absorption. And dedicated Winter/Snow tires if you're going to the trouble of swapping rims seasonally, esp. in NH.
    I run some hand-me-down +34 Rial DH's with 245x40x18 Michelin Alpin's and they are near flush with the external wheel wheels. However consider that although perhaps better looking they will throw up more sand/salt vs. a more "tucked in" higher positive offset (OEM is +50).
    The MkIII TT/TTS doesn't have TPMS sensors in the tires but rather utilizes computed differences in rim rotation via ABS/MMI to alert under/over pressure.
    [However the TTRS does have TPMS sensors so as to get an accurate track-oriented per tire readout for its display.]
    Quote Originally Posted by jester7677 View Post
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Mar 24 2007
    NH
    hmmm, yes, this really helps. Thanks!
    2018 Audi SQ5
    2004 Audi S4 (gone)
    2000 Audi S4 (gone)
    Veteran Member Three Rings Izzu's Avatar
    May 06 2013
    California
    Quote Originally Posted by Huey52 View Post
    Isn't that considered the direct TPMS option that only comes with the Dynamic Plus Package? Otherwise it's just like the TT/TTS?
    2021 SQ5 - Glacier White
    2018 TTRS - Suzuka Grey (Sold )
    2013 S4 - Monsoon Grey (Sold)
    2012 A5 - Glacier White (Sold)
    Dec 22 2010
    New England
    In the US yes, but options vary worldwide.
    Quote Originally Posted by Izzu View Post
    Jun 14 2005
    Anaheim, CA
    Here is a couple of customer submitted MK3 TT-S:
    Customer submitted MK3 TT-S with winter set up
    VMR V718 18x8.5 ET45.
    Tires are Michelin Pilot Alpins but sadly, unsure of size as the customer had them done local.
    This one was emailed to us last year but MK3 TT-S
    VMR V705 19x8.5 ET35
    Tire spec is unknown as they had them sourced local.
    Hope these two pics gives a good idea of what these offsets look like on a MK3 TT-S! I'm sure we'll have more to share soon.
    Brandon @ VMR Wheels
    Veteran Member Three Rings SebringSilver's Avatar
    Oct 04 2006
    TT RS
    Vancouver, Canada
    Picked up a 2018 TTS last month with the 20” wheels and the Yokohama summer tires. But with winter coming (thankfully mild winters), I bought a set of 19” BBS CH-R wheels for winter duty. Here are the specs:
    Satin Titanium
    19x9.5 +45
    Will be pairing them with Continental DWS 06s in 255/35ZR-19.
    I’ll post pics when they’ve been installed.
    Currently Driving: '18 TT RS | '18 Velar P380 HSE First Edition
    Gone and Missed: '18 TTS | '14 991 C4S | '11 R8 V10 | '09 R8 V8 | '09 C63 AMG | '06 B7 S4 | '94 NSX | '92 NSX
    Junior Member Two Rings
    Sep 20 2017
    Huntsville, AL
    From Neuspeed RSe102:
    • Size: 19x9.0
    • Offset (E.T.): +45mm
    • PCD (Bolt Pattern): 5-112
    • Center Bore: 66.5mm / 57.1mm (with hub ring)
    • Weight: 20.8 lbs.
    Says that 255/35's might rub.
    Feb 01 2015
    2017 Subaru Outback
    United States
    I have Neuspeed wheels in that size, they don't rub, with 265/30's, so feel fairly sure that 255/35 won't either.
    2016 TTS
    Sep 20 2017
    Huntsville, AL
    Quote Originally Posted by mossback View Post
    Thanks. 255/35/19 keeps perfect wheel diameter match to stock.
    I may just replace my OEM's in the spring with these as well as installing DSW's on these for this winter. Here winter is mostly just cold rain, even w/o the snow makes for dicey driving with Summer Tires.
    Mar 10 2017
    TX/USA
    Any reason you went with 265s? I'm about to go this route for track and street wheels and was planning on 255s for both as most tire manufacturers seem to suggest this on 9" wheels for best handling, so I'm curious on your take!
    Feb 01 2015
    2017 Subaru Outback
    United States
    The tire choice was somewhat limited, I wanted Pirelli Corsa and Trofeo R, the tires are slightly shorter so acceleration is a bit quicker. I run 265/35 18 in the trofeo and 265/30 on the 19.
    2016 TTS
    Established Member Two Rings BradB's Avatar
    Dec 26 2010
    St. Louis
    I never knew that they didn't have TPMS sensors. So if I get an optional set of wheels/tires I need to do nothing more. (?) And what happens if my choice of tire gives me a diameter range that is slightly off from OEM spec? For instance, I am looking at a tire size that is slightly taller in diameter (26.1 OEM, 26.8 aftermarket) so would that work or throw some sort of warning??
    Thanks in advance for any comments!
    The Stable
    2017 Audi TTS
    2017 Porsche Macan GTS
    2014 Porsche Carrera S
    1996 Porsche Carrera 4S
    1973 BMW 2002tii
    Link to my garage pics.
    Veteran Member Three Rings Chuckster's Avatar
    Feb 18 2017
    Socal
    Square setup
    2017 Audi TTS | Sold |
    2019 Audi Q7 | Baby seats |
    Senior Member Two Rings chasiu's Avatar
    Jul 31 2014
    Toronto, Ontario, Canada
    Quote Originally Posted by TheBigFish View Post
    • Size: 19x9.0
    • Weight: 20.8 lbs.
    any pictures of these mounted on the car?
    Dec 22 2010
    New England
    Yes
    https://www.tirerack.com/snow/Winter...=W&search=true
    Quote Originally Posted by reyoasian View Post
    Do any 17s fit? For winter and track.
    May 07 2018
    Cleveland, Ohio
    Has anyone successfully fitted 17 inch wheels?
    I take delivery of my TTS in 1 week and i'm really looking for a good 17" setup for winter. I want to keep the same diameter so I'm thinking 45 sidewall? I live in Cleveland Ohio and the roads are unacceptable during the winter.
    Feb 18 2017
    Socal
    Just ordered these 20x9et35 with 265/30/20 MPS4...
    Feb 18 2017
    Socal
    Quote Originally Posted by Chuckster View Post
    So these are rubbing in the back over even modest bumps. The rear fenders don’t really have a lip to roll for extra clearance.
    BRKNJMPR has this same wheel on his TTRS lowered with MSS and a larger 275/30/20 MPS4’s and states no problem, so any ideas why my smaller 265’s won’t clear?
    The rear wheel to fender gap is 15.8mm.
    The rear camber is -1.4 degrees. (Spec range is -1.8 to 0.8)
    Senior Member Three Rings Rapture's Avatar
    Dec 14 2006
    Milwaukee
    Dumb question, but did you check the stamping on the rims to make sure they are the offset you were expecting?
    Rapture
    2018 Audi TT RS (Gray/Black, Palomino)
    2014 Porsche C4S GT Silver (Sold)
    2011 BMW 1M Coupe AW (Sold)
    2007 Audi RS4 Lava Grey Pearl (Sold)
    2004 VW R32 Silver (Sold)
    Dec 21 2017
    Los Angeles, CA
    Could be the tires. Michelin PSS run big
    Dec 21 2017
    Los Angeles, CA
    Quote Originally Posted by BradB View Post
    I’d like to know this as well. Does the TT mk3 not have tpms sensors?
    Feb 18 2017
    Socal
    Quote Originally Posted by Rapture View Post
    Yes.
    Feb 18 2017
    Socal
    Quote Originally Posted by littlejuanito View Post
    Not PSS, PS4S...same tire as others posted have had no issues at the 275 size.
    Feb 18 2017
    Socal
    I don’t think so. Our TPMS takes readings from differential and ABS to monitor tires.
    Feb 18 2017
    Socal
    I raised the rear 1/8” to the oem height and it still rubs. I don’t see how these will fit. I’ll take it to the shop and see if the oem 255 fit with these 20x9et35 HRE’s.
    Dec 14 2006
    Milwaukee
    I run a stock suspension (currently) with HRE wheels. The rear's are 20X9.5 ET 40, so they should be 1.3 MM further out. I also have the 265/30/20 MPS4 tires and have not had any rubbing. I just went to check again to be sure.
    Strange.
    Rapture
    Feb 18 2017
    Socal
    Strange.
    What’s your rear alignment set at?
    I have camber at -1.4 and toe is .21-.23
    Established Member Two Rings 95wildtt's Avatar
    Aug 22 2015
    Carmel, IN USA
    What suspension are you running?
    Maybe the spring rates are lower/softer than the stock TTS rears, so you're getting more body roll...??
    FWIW, I'm also running 20 x 9.5, but with a 40 offset (ABT FRs) and 275/30-20 DWS06s, and no rubbing...
    Stock suspension.
    Just a thought....
    Gone: '18 Tango Red Metallic TTS | Rotor Grey Fine Nappa | Black Optic + Fuel Door & Emblems | Tech Package | B&O | RoW OLEDs | ABT FR20s
    150:2018 US TTS / 11:In Tango Red Metallic / #1 of 2:With Rotor Gray
    2020 BMW X3M (Non-Comp)
    1995 Dodge Stealth Twin Turbo
    Dec 14 2006
    Milwaukee
    I don’t have the exact specs, the car is very new, only about 500 miles so far. Whatever it was set at the factory. Definitely some camber dialed in.
    I also wonder if the aftermarket springs my be a bit softer?
    Rapture
    Feb 18 2017
    Socal
    Quote Originally Posted by 95wildtt View Post
    Not stock, of course...
    I'm also running 20x9.5, but with a 40 offset (ABT FRs) and 275/30-20 DS 06s on the rears, and no rubbing...
    Stock suspension.
    Very odd.
    MSS Kits Street.
    I don’t know the sidewall shape differences between Conti v Michelin....but PS4S are on the taller side anyhow.
    To be clear, I’m rubbing when the springs compress (driveway, turns, speed bumps, etc). Just sitting on the ground, everything is fine.
    Feb 18 2017
    Socal
    I set the mag to dynamic on the way home, which seemed to help avoid rubbing on highway bumps. Any speed bump or driveway is unbearable though. Factory camber is around -1.4/-1.6, but this seems more than a 0.2” problem.
    Dec 14 2006
    Milwaukee
    I wonder if the sport or track springs may work better than the streets?
    Rapture
    Feb 18 2017
    Socal
    Maybe. Probably better ride comfort to go with 255 + Streets than 265 + Sport/Track for a street car though. I should have went to 19”.
    The first Street MSS was done by TAG with the same wheel specs, but with oem tire specs...so 255 is supposedly the tried and true answer.
    Feb 18 2017
    Socal
    Compared to the HRE’s with the larger tires, the oem forged 20’s aren’t as light as I thought.
    Feb 18 2017
    Socal
    Problem Solved = Adjusted rear camber from -1.4 to -2.0
    Dec 14 2006
    Milwaukee
    That’s great news! What height are you at now? I know you had raised it to stock height recently.
    Do you like the ride of the MSSkit more than stock?
    I’d like to order these but have been on the fence after watching this thread. I would only lower the ride a half inch or so due to a very steep incline into our underground parking.
    Rapture
    Feb 18 2017
    Socal
    The MSS Street imo is very soft...makes it feel like stock, just lower. This is great for ride comfort, but not suspension travel on the wheels and tires I chose. The clearance is with it back in the lowered position. I’ll snap a pic when I can clean the car over the weekend.
