I'm getting a 02256 - Quiescent Current fault in the CAN Gateway. From some other sources it looks to be a battery issue. Do my stats look off? The code came up on 8/18 and I noticed it today after a scan. I cleared the code and it hasn't come back but I still can't fully use my outlets. My battery is currently the original and is 7 years old.
Symptoms: I can not use the 12V outlets, they were working fine last week. I can pull USB power through the other power slot on the phone charger but the hardwire (USB-C) doesn't work on either 12V outlet.
edit: could be a fuse? Wouldn't make much sense there though since I can still draw low power from it.
