My searching lead me to one main conclusion, my evap system is not venting as it should. And since there is no leak in the system, I have no codes for it. Makes sense, so where do I go from there? I've read up on all the trouble filling gas threads, hoping someone would have experienced this before, but to no avail. I got the car up in the air the other day to take a look. The passenger side fender well makes a "clicking" noise when I purge the air through the gas cap, so I started here. No obvious filters, nothing that really appears to be clogged, so I moved on to the other side. I pulled the filter out from that side and cleaned it up a bit, nothing crazy in it. I let the car sit for a few hours, and checked. No air. I drove it later that night. No air. I drove again the next day. This time, it released enough air to shoot the cap off again. My next step is to pick up a new charcoal canister (maybe a cheap one from a junk yard), to see if that helps solve the problem, and see about cleaning mine out in the process. PS: is there a difference between the charcoal canister in the 3.0 vs the 1.8T? I can Google that, but if anyone already knows...
Any other suggestions/things to be checking? I was expecting having trouble filling properly, but not this.
