Results 1 to 22 of 22
    Jul 22 2011
    C7 A6 Prestige. 1977 Datsun 280z
    New York
    o2 sensor spacer.
    Just purchased a 42DD sensor spacer for my 2010 2.0t hoping it would take the CEL away from having a test pipe. I've tried different configurations of the spacer and still a check engine light will be there as quickly as I erase it. Is there any other sensor spacers that are worth trying? Also heard revo stage 2 would be an option as it changes the sensitivity of the secondary sensor? Any help would be appreciated need to pass inspection and have the readiness monitors set!
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    There are likely different solutions, up to an including disabling the rear 02 and or hard coding it with a predefined "good" value. As for spacers, each car is different, some work with one spacer, some work by doubling them up, some only work with the mini-cat spacers. Takes a bit of testing. That being said, I have a non-catted spacer if you need/want to try another one. PM for details.
    Jan 03 2013
    Baltimore
    Are you chipped? Best bet is to have the stock program available and switch to that for emissions. If they visually inspect then you may need to put the stock cat back on. I run APR and have the stage II 93 file and stock. When it's emissions time, I switch to stock get tested and switch back.
    Fwiw, I have the 42dd spacer on the 034 hfc and do not have a MIL on either program.
    Sent from my Pixel using Tapatalk
    Nov 23 2009
    NYC, US
    Quote Originally Posted by elscotto80 View Post
    Are you chipped? I run APR and have the stage II 93 file and stock. When it's emissions time, I switch to stock get tested and switch back.
    Does it work every single time?
    Jan 03 2013
    Baltimore
    Does what work? I have only done emissions once this way being chipped. I tried with stage II app and it failed. Added the stock program, switched to that (no change to hfc or sensor setup) and took it back, passed.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by IHave2Turbos View Post
    Who has ever hard coded it to a predefined good value? Thought the most we were able to do is delete the codes but then it doesn't complete the readiness tests. I keep getting P2271 on mine with the 034 HFC and right angle spacer.
    Jul 22 2011
    New York
    Okay maybe I'll try the catted version spacer since I have a non catted one now. Thanks a lot I'll definitely try some different configurations
    Dec 01 2011
    Roc-Euro spacer with catalyst, it's almost guaranteed to work, best reviews i've seen and best success rate out of all spacers. i've been running mine for like close to 2 years now, code hasn't returned at all. worth it, it's like $35 or so. i think i got the 90 degree one im not sure, but the straight one should work fine too.
    https://roc-euro.com/collections/acc.../sensor-spacer
    IG @theshawon
    Nov 23 2009
    NYC, US
    Quote Originally Posted by Liquid Smoke View Post
    What HFC and dp are you using now with Roc-Euro spacer?
    Dec 01 2011
    Quote Originally Posted by AutoRacer100 View Post
    i'm actually still on the stock cat, no mods there. the reason for the spacer was because my stock cat was throwing error codes, i was at like 100k miles at the time (125k now), so my oem cat was prob going bad. i originally got the spacer to pass inspection and then eventually replace the cat or get a HFC, but the error never came back after the spacer so i've just left it for now, but still do plan to get a HFC very soon and will keep this same spacer. and before i got the spacer, i cleared and had that error for a few weeks, it was definitely the stock cat throwing the error after multiple cleared codes, so not a coincidence or anything that the spacer happened to be there when the errors stopped.
    IG @theshawon
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    My HFC is from Eurocode, and I have a Roc-Euro 45° catted spacer; works like a charm. Only advice, call them after you place your order or even before; they can be slow to ship, but it was actually on the shelf when I bought mine even though the site said it wasn't.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 23 2009
    NYC, US
    Quote Originally Posted by bakedziti View Post
    Wow, thanks for the feedback. So should I pull the trigger on APR DP now? It's very attempting after seeing this reply.
    Dec 01 2011
    be careful with HFC vs Downpipe. the HFC may work well with the spacer as it's already got a catalyst, but the DP are just wide open i believe and there's less chance of the spacer working on that error-free as it will on an HFC.
    IG @theshawon
    Nov 23 2009
    NYC, US
    The APR dp comes with a HFC.
    Oct 23 2014
    Buffalo, NY
    Isn't the APR DP an HFC and the downpipe combined? If so, I recall it being catted, and it should work pretty well with that spacer. Obviously, your results could be different, but its worked very well for me.
    °2011 A4 | 6MT
    Nov 23 2009
    NYC, US
    You have Roc-Euro 45 degree spacer on APR dp/HFC?
    Dec 01 2011
    sorry disregard that, i was thinking TESTpipe instead of downpipe haha
    IG @theshawon
    Oct 23 2014
    Buffalo, NY
    No, I have a Eurocode HFC followed by a stasis catback, no issues here.
    °2011 A4 | 6MT
    Nov 23 2009
    NYC, US
    Does aftermarket dp removes the stock resonator?
    @bakedziti, so you have Eurocode HFC and stock dp, then a full catback Stasis. The full catback statsis exhaust starts right after the stock dp? I've always thought catback exhaust starts right after the cat. That's why it is called catback.
    Oct 23 2014
    Buffalo, NY
    o2 sensor spacer.
    The DP answer is all dependent upon who's making it, and what they refer to as a DP. Eurocode's HFC is simply a 200 cell cat, but doesn't include the DP. The stasis catback is exactly what it sounds like, and completes the exhaust after the cat. Audi technically refers to the DP as the piece after the cat. I think you're confused because APR markets theirs as a two piece HFC with a DP. 034; Eurocode; Spulen; etc don't do that.
    EDIT: images help
    Eurocode HFC:
    Stasis exhaust: the pipe all the way in the back of the image is the DP, and mine is resonated.
    APR's HFC with a DP that I believe they call the DP:
    Audi DP:
    °2011 A4 | 6MT
    Nov 23 2009
    NYC, US
    Thanks for clarifying and the pics.
    I know Stasis is no longer in the exhaust business. If I have APR dp and a full Stasis exhaust. Then I will have extra dp. APR dp with HFC and full stasis exhaust starts after the cat.
    Aug 15 2015
    Prosper, TX
    Wouldn't that leave you with an extra HFC, if the APR downpipe includes a HFC. If you do have an extra HFC, I'll buy it from you if unused.
    2009 Audi A4 Quattro / Prestige / Phantom Black Pearl / APR Stage II / GFB DV+
