Results 1 to 8 of 8
    Sep 23 2017
    Hong Kong
    P2187 along with P0441 fault code...
    Hi All, my A4 (2005model) recently got check engine light on, then I went to a local garage and was told to change MAF sensor. Few days after they changed it, the engine light turned on again...I feel very frustrated...then I bought a Xtool Vag401 tool and checked the car myself and got below 2 codes :
    P2187 - System Too Lean at Idle (Bank 1)
    P0441 - Evaporative Emission System Incorrect Purge Flow
    Any bro have similar experience or ideas how I can get rid of them ? And could I continue driving before I get it fixed? Many thanks!
    Oct 24 2015
    Perth, WA
    Replace N80 valve (they're cheap and easy DIY) and use a can of carby or brake cleaner and spray carefully near all areas that could be leaking in the vaccum lines and anywhere between the MAF to the throttle body. Check PCV, or replace (they do need replacing quite regularly. If you get excessive vacuum on when removing the oil cap with the engine on I believe your PCV is probably ok, however this is not a fool-proof test.
    The reason its running too lean is probably due to un-metered air entering the intake thus preventing the ECU from calculating the amount of air entering. Air/Fuel ratio is out.
    The evap purge issue is your N80.
    Replacing the PCV, N80 and checking for vacuum leaks will sort this.
    Edit
    Looking back at your post, no, try not to drive it like this. If you must, stay off boost.
    The garage that you went to probably left a loose clamp on a intake piping. Double check.
    My respray thread
    Veteran Member Three Rings B7S3wannabi's Avatar
    Mar 27 2017
    2005 ZCP Competition M3, 2016 Audi S3, 2018 Tesla M3P, 2016 Ducati 959
    Loudoun County, VA
    As Oke said. Most likely the N80 valve is faulty. Remove it and see if you can blow through it (you should not be able to). That would account for both codes.
    Sep 23 2017
    Hong Kong
    Thanks Oke, Wannabi! Very helpful information. Yesterday I cleared the fault code and then drive a while to get the engine light in order to confirm the fault code. Interestingly this time only P0441 detected. Can I assume P0441 trigger or correlate to P2187? And the strategy remains the same i.e. Change the N80?
    Mar 27 2017
    Loudoun County, VA
    Quote Originally Posted by henryhenry View Post
    Yes. Means the purge (n80) valve is stuck open. This will cause the P2187 to trip soon.
    Sep 23 2017
    Hong Kong
    Quote Originally Posted by B7S3wannabi View Post
    Many thanks, hope I can get it fixed soon!
    By the way, where do u usually buy the parts? ebay?
    Established Member Two Rings 1broknrado's Avatar
    Jul 09 2012
    Charlotte NC
    FCPEuro.com or ECStuning.com
    Junior Member Two Rings
    Nov 26 2018
    Vermont
    Quote Originally Posted by Okedokey View Post
    Edit
    Could a bad pcv cause the p0441 ? I’ve changed the n80 and also gas cap seal and can’t see any visible signs of vac leaks,
