Had the car about a year with working AC, blew nice and cold, nothing out of the ordinary. Today it suddenly stopped working - compressor clutch will not engage, the compressor shaft feels normal and spins freely. No VCDS codes at all, compressor clutch voltage in VCDS reports +13 and compressor "on" is 1.0 when I have ECON off. I figure if it was a pressure problem VCDS would report something. I've never had any leaks in the system and I use AC all the time and have seen no deteriorating performance.
I strongly suspect I've done something, as I was working in that area with the auxiliary fan controller, I pulled it off the mount and inspected it, and remounted it afterwards. My secondary fan has not worked since I got the car, it doesn't appear to be a problem with the controller as it does output +13V to the fan, and when I tested the terminals on the fan I get an open loop so I figure the fan is shot. The only time it impacts AC performance is sitting in traffic, as I would expect. I haven't pulled the front clip off the car to work on the fan yet.
The AC did work after I reinstalled the fan controller, for about 45 minutes - so it may be a massive coincidence... but I find that hard to believe since I was messing around in there - but as I understand it this does not effect compressor start/stop? Any help sure is appreciated. Could i have bumped or damaged a critical connector for the AC compressor in that area?
