Originally Posted by
uzone02
What other mod you did to it ?
First, the engine is a stock 1.8T AMB block and head. Was purchased as remanufactured by Audi when my original motor blew at 237k miles. With the new engine, I sent the transmission out to a specialist in Texas to have it rebuilt. They cryo treated the gears for added strength. They also added shims to the center differential from the original 2:1 ratio to 4:1 ratio to make the power distribution more like the RS4 (40/60).
Here's the whole mod setup...
GT2871R Eliminator turbo
Bosch 550cc injectors
Motoza tuning
Bosch 440 drop in fuel pump
034 braided fuel line from fuel filter to engine
034 billet aluminum fuel rail
Fluidampr pulley
OEM Audi BEX exhaust manifold (had it ceramic coated)
034 HFC
APR 2.5" downpipe
Magnaflow 16601 exhaust
Evolution Racewerks Comp FMIC
ECS Tuning RA4 Stage 2 clutch w/ steel flywheel
JHM short shift and solid linkage
Samco Sport diverter valve
2.0 TFSI ignition coils
NGK BKR7E-IX spark plugs
Bilstein PSS9 coilovers
Stoptech 332mm BBK (slotted)
ECS Tuning B6 S4 rear brake kit w/ 2 piece slotted rotors
Probably some other small items I'm forgetting too (not to mention cosmetic mods)
