Results 1 to 40 of 48
    Sep 14 2017
    Watertown
    f/s a5/s5/rs5 cabrio oem carbon fiber spoiler!
    All of these have been sold! Thank you
    P# 8F0-827-933
    EDIT:
    D172090A2 This is the adhesive
    D00940104 This is the cleaner
    You will need these as well to make a more permanent adhere.
    No drilling required for this.
    Sep 14 2017
    Watertown
    bump Still got this bad boy
    Sep 14 2017
    Watertown
    bump price drop to get rid of this. Lowest we can go.
    $450.00 Shipped
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    Tempting. How does it attach to the trunk?
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
    Sep 14 2017
    Watertown
    This has a adhesive back but your suppose to use Audi Primer/Adhesive also. Its like a cement.
    May 12 2017
    Steel City, USA
    Quote Originally Posted by chillybone View Post
    So I don't need to drill through the trunk? I will ask the local body shop if they can get Audi adhesive and install.
    -Joe
    Sep 14 2017
    Watertown
    No drilling required!
    D172090A2 Is the adhesive
    D00940104 This is the Cleaner
    May 12 2017
    Steel City, USA
    Bit too pricey for me.
    -Joe
    Sep 14 2017
    Watertown
    still got!
    Sep 14 2017
    Watertown
    Sold 1!
    3 left
    Nov 06 2017
    By chance u don't have one for a B9 SB ?
    Sep 14 2017
    Watertown
    Quote Originally Posted by coupegt7 View Post
    I couldn't find one as cheap but here is a one with a good discount.
    https://parts.valentiaudi.com/p/SPOI...71641A3Q0.html
    Sep 14 2017
    Watertown
    bump
    Sep 14 2017
    Watertown
    still have this one!
    Established Member Two Rings ghgoldberg's Avatar
    May 28 2012
    Pittsburgh, PA
    Would this fit a 2012 S5 Cabriolet? When I research the part number, it comes up with compatible years of 2013—2015.
    Sent from my LGLS992 using Audizine mobile app
    May 28 2012
    Pittsburgh, PA
    PM sent
    Veteran Member Four Rings Ms.S4's Avatar
    Apr 25 2012
    S4/S5/A7...we love Audis!!!
    Wow this is an amazing price.
    Stage 2 S5 cab - *brilliant/magma*sports diff*BCForged*H&R*Pirelli*AWE*Built with Love <3*
    May 28 2012
    Pittsburgh, PA
    I received the package today. The thing is beautiful and fits perfectly. Thanks Brian.
    Sep 14 2017
    Watertown
    Wonderful! Glad your happy with it. It’s really an attractive piece.
    May 28 2012
    Pittsburgh, PA
    Installed.
    Sep 14 2017
    Watertown
    Beautiful! Love the carbon fiber look.
    Established Member Two Rings voodoo33's Avatar
    Apr 04 2011
    Orlando
    how does this fit all models? im pretty sure each trunk is different for the cab, s5 and a5.
    Sep 14 2017
    Watertown
    This fits cab models only a cab s cab and rs cab.
    I test fitted this to make sure on all a5-rs5 cabs before I listed.
    I have 2 spoilers left before they are gone for good.
    May 28 2012
    Pittsburgh, PA
    Quote Originally Posted by voodoo33 View Post
    It will fit any 2010-2016 cabriolet A5, S5, or RS5. You can verify this by checking compatibility for the trunk lid, Audi PN: 8F0827023D.
    Another pic:
    Sep 14 2017
    Watertown
    bump 2 left!
    Sep 14 2017
    Watertown
    bump!
    Sep 14 2017
    Watertown
    Bump!
    Sep 14 2017
    Watertown
    bump!
    Sep 14 2017
    Watertown
    Bump still have 2 left before they are gone for this price.
    Veteran Member Three Rings AudiFamilyGuy06's Avatar
    Aug 23 2015
    Simsbury, CT
    CHillybone,
    Do you work at Valenti? I am in Simsbury. If so if I drive down can I put one on my trunk (not stick it, just place it) to see if I like it?
    Regards, Joe
    Jul 25 2011
    i wonder if this would fit over the RS5 Coupe active wing?
    Sep 14 2017
    Watertown
    Quote Originally Posted by Beast View Post
    This wont fit. Its not snug in the first place and the wing would get in the way I believe...... its been awhile since I test fitted the rs5 coupe with this.
    - - - Updated - - -
    Quote Originally Posted by AudiFamilyGuy06 View Post
    CHillybone,
    Regards, Joe
    Sure joe you can come on down. Give me a time frame so I can make myself available.
    Sep 14 2017
    Watertown
    BUMP!
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    PM sent. I am interested
    Thanks
    Jan 13 2017
    marlton/nj/usa
    I put it on a couple days ago. Thanks Brian. It is better than I thought.
    The RS5 spoiler is perfect size for the S5. I had been considering the larger Audi accessory spoiler (there are two, a low profile and a larger) I recently found someone who was trying the larger and it is ugly. Too big for a stock S5 and has a flat tip that mimics the S5 cab trunk line. The RS5 spoiler is in between in size. It is bigger than I thought from other posts of Cabs with the RS5 spoiler. The other thing I was un sure of was the carbon fiber. I am not big on CF details/accessories and I did not want the spoiler to stand out. It works great and is subtle IMHO with my Estroil Blue and works with the black roof.
    Sep 14 2017
    Watertown
    Thank you for sharing. It is a beautiful piece.
    I have 1 left someone cancelled on before they are gone.
    Anyone!?
    May 28 2012
    Pittsburgh, PA
    Quote Originally Posted by Neil F View Post
    I put it on a couple days ago. Thanks Brian. It is better than I thought. ... It works great and is subtle IMHO with my Estroil Blue and works with the black roof.
    Looks great.
    And it works too! I noticed a pronounced line of dirt under mine at the interface with the lid. And I haven't had it over 80 since I installed it. So, it is definitely pulling a suction on the bottom of the spoiler. I don't know how much downforce it is generating, but at higher speeds it would likely be something not insignificant.
    G-
    Sep 14 2017
    Watertown
    One more left bump
    Jul 25 2011
    you sure this won't fit on a RS5 coupe? Looks like it could fit onto of the active wing as an additional lip.
    Established Member Two Rings tec15's Avatar
    Jul 14 2015
    I’ll take it
