Results 1 to 40 of 69
Thread: k04 Power
    Deactivated Three Rings
    Nov 18 2016
    Tokyo japan
    k04 Power
    I have k04 maf & tt 225 injecter power 300 hp. Because it is AT, I am worried about the rod so I will lower it to 280hp. How much power do you all have? k04 Limited
    Jul 14 2009
    Pasadena
    LOL like I told you before, no way you can make 300hp on k04 with those injectors. not even to the crank. Do I need to show you a dyno to prove it?
    AT and rods will be fine with a k04.
    IG: @matthewee
    Nov 18 2016
    Tokyo japan
    ecu is stage two. In the Dyno test, it went up to 298 horsepower. But I will adjust it to 280 horsepower. All right?
    Jul 14 2009
    Pasadena
    I would pay money to see a dyno chart of a stock motor with k04 and tt225 injecors making 300hp.
    IG: @matthewee
    Nov 18 2016
    Tokyo japan
    If you reduce the margin and adjust the parameters to the limit value, you can afford to purchase the turbo. Japan is doing it. TAP and MTM are close to ideal. Fully match the air / fuel ratio.
    Jul 14 2009
    Pasadena
    Quote Originally Posted by goa View Post
    SHOW ME YOUR DYNO with K04 and tt225 injectors making 300hp.
    IG: @matthewee
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    How about a log showing the MAF readings?
    300 wheel HP is something like 350+ HP at the crank. That is physically not possible with the injectors and turbo you are running.
    2019 SQ5 Prestige
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    K04 the little turbo that couldnt...
    Its a good temporary thrill giver but long term it promises but falls short right when things were getting fun...
    I would like to know what dyno - definitely not a Mustang.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Dec 05 2007
    Nothing is impossible, as long as you put your mind to it
    Senior Member Three Rings sleepwalker_gsr's Avatar
    Jul 08 2010
    Your mom, tied up.....
    sacramento CA
    What injectors come with the APR k04 kit?
    2003 B6: GT2871R turbo, Snow Performance Water Meth, Motoza tune, FMIC, Straight pipe, ECS RA4 Stage2 Clutch, 034 fuel pump, 034 TIP, Bosch 550cc injectors, fuel rail, 008 DV, Carbonio intake, coilovers, S4 door blades, USP front bumper and painted lowers.
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    Quote Originally Posted by itsmatt33 View Post
    Not true, I made just over 300 crank on my k04.
    Edit: with BOSCH 550's
    You win some, you lose some...
    Nov 18 2016
    Tokyo japan
    ahha
    Nov 18 2016
    Tokyo japan
    Both test pipe and muffler
    - - - Updated - - -
    yes
    Nov 18 2016
    Tokyo japan
    apr is k04 and it is 245hp. gt 28 rs
    - - - Updated - - -
    ok💟
    - - - Updated - - -
    OK
    Nov 18 2016
    Tokyo japan
    300 will be about 280hp.
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Quote Originally Posted by KHARDa4 View Post
    What tune?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Jul 14 2009
    Pasadena
    Are we seriously going to debate this. K04 does NOT make 300hp on tt225 injectors. Not even with race gas.
    IG: @matthewee
    Dec 30 2014
    South Carolina
    Quote Originally Posted by gtsingh91 View Post
    What tune?
    Motoza performance w/ e85.
    Jul 14 2009
    Pasadena
    I am still skeptical. Metal Man didnt even break 300 on franken turbo
    http://www.audizine.com/forum/showth...7awhp-309-awtq
    IG: @matthewee
    Dec 05 2007
    I almost cracked 400whp with the stock k03. Upgraded to a 5152 turbo, and it seems I am making less horse power. Don't know what I'm doing wrong
    Jun 27 2011
    Thats just because you're a big dummy though.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    Makes me want to dyno after a couple revisions. Working on the E85 tune right now with Dave/Motoza. Curious if I'd get any closer than metalman to breaking the 300hp mark.
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Dec 05 2007
    You're mean 😢. I'm not inviting you to my next birthday party.
    Nov 18 2016
    Tokyo japan
    I know that apr's K 04 only gains 247hp. 250 hp ssp in GIAC 258 hp speed 289 hp united 270hp
    Nov 18 2016
    Tokyo japan
    k03?🤔🤔?
    Nov 18 2016
    Tokyo japan
    motoza something power does not rise at all.
    - - - Updated - - -
    Motoza something power does not rise at all.
    Nov 18 2016
    Tokyo japan
    uni stage2+ 265hp
    Nov 18 2016
    Tokyo japan
    Why can not you say there is no 300hp? Is not at least 290 hp possible with GIAC? test pipe maf & TT 225
    Dec 05 2007
    k03?🤔🤔?
    Nice to see you can take a joke 😎
    Nov 18 2016
    Tokyo japan
    I think that it will go up to 290 hp at K 04. 440 cc or 550 cc may not be necessary. More than that requires GT 28RS.
    Nov 18 2016
    Tokyo japan
    Quote Originally Posted by texasboy21 View Post
    300hp japan ecu tuning💟💟
    Nov 18 2016
    Tokyo japan
    It's 265 hp with uni stage 2 +.
    Nov 18 2016
    Tokyo japan
    https://youtu.be/c3L0mWk5dJo
    - - - Updated - - -
    - - - Updated - - -
    Dec 05 2007
    Bump for having 1,234 views when I posted...and my post possibly being the 1,235th view
    Jun 27 2011
    k04 Power
    I wanna get me some of that 450hp k04 action, dawg.
    Also, I almost don’t want to ask, but wtf is that last video? 1.8t k04 tfsi? Dafuq does that even mean? Is it an FSI k04? Where are they getting tfsi? Because the k04-064 is a LOT different than a k04-015 but it’s from the ea113 FSI 2.0t (same turbo from the S3 and Mk6 Golf R) but those engines aren’t tfsi. So yea...
    They also barely top 300chp on a 2.0t so hitting that on a 1.8t is tough.
    -CP
    2017 Q7 3.0t
    Jun 26 2015
    Tampa, FL
    Wow, that's your proof I guess everyone here has been proven wrong now.
    Jul 03 2013
    Bulgaria
    Using a tfsi turbo on a 1.8t is a relatively popular mod in Europe. You can use regular k03 from tfsi or go with the k04-064. You need an adapter plate for the monifold and downpipe and intake fittings. http://forums.vwvortex.com/showthrea...-adapter-plate
    With a k04-064 , exhaust , intercooler and everything else needed, you can reach 300+ hp on 1.8t
    Nov 18 2016
    Tokyo japan
    ma-ne.
    Nov 18 2016
    Tokyo japan
    ahha
    - - - Updated - - -
    Quote Originally Posted by danidelev View Post
    - - - Updated - - -
    Quote Originally Posted by rocket1420 View Post
    yes💟
    Apr 01 2007
    houston texas
    But with 386cc injectors?
    Obviously there is something lost in translation. The OP has not specified which K04 he is running.
    2019 SQ5 Prestige
