Results 1 to 3 of 3
    Junior Member Two Rings YourPalBigAL's Avatar
    Jan 01 2014
    2000 Chevy Silverado HD 6.0l
    United States
    B5 A4/S4 calipers on B4?
    Does anyone know if the rear calipers off of a b5 will swap directly into a b4? Just bought a 1995 Audi 90 last night and the rear brakes are so effed. Calipers and rotors are junk. Figured it's a lot easier to source b5 parts than it is b4, so if the calipers will fit I will just buy some b5 calipers from the junk yard.
    01 Santorin B5S4
    02 Silvaro B5S4 Avant
    95 Audi 90q
    01 Silvaro B5S4
    01 Chevy Silverado 2500HD
    May 28 2014
    Atlanta, GA
    yes direct fit
    Established Member Two Rings ralleyquattro's Avatar
    Feb 02 2013
    Toronto/Canada
    I used a B6 calipers, new are cheap and available anywhere, you have to re-route the flex line, not a big deal.
    S4 caliper will require you to get creative with rotor choices.
    Best to go straight for 5 bolt and swap the B5 A4 hubs at the same time... ;)
    Martin Pajak
    http://www.quattro.ca
    2004 Audi A4 quattro avant 1.8T UPS 6-speed
