Results 1 to 7 of 7
    Jan 10 2017
    CA
    Tire rotation pattern
    Dumb question alert -- what do you folks do for your tire rotation pattern? Just switch front to back or also cross (ie, rear tires move forward on the same side and fronts go to opposite side rear). Dr. Google tells me the latter is best for 4wd/awd vehicles, tire shop says otherwise. My guess was tire shop is just lazy/uninformed, but figured I'd check with more knowledgeable people on here before stating anything definitive.
    thanks
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    What does your owners manual say?
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Mar 17 2017
    Redondo Beach, CA
    You can only coss rotate if you don't have unidirectional(designed to rotate one direction only) tires. Most summer and high performance tires are unidirectional and must be rotated on the same side. But you can also pay extra for a shop to unmount/remount tires to switch which side of your tires face out on unidirectional tires, useful if you know you have minor camber wear and want to even it out, I do this on my other car.
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
    Jan 10 2017
    CA
    Quote Originally Posted by SleekS7 View Post
    Thanks, that is helpful. For some reason I didnt think the tires were unidirectional but that makes sense. Like I said -- dumb question alert! From the couple times I've jacked up the car recently to do exhaust work it does appear I'm getting minor uneven camber wear, but I guess I'll just let it go and benefit for the 30k tread warranty if they need to be replaced sooner...
    Appreciate the quick response.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    The move has been away from unidirectional summer tires and toward asymmetric tires which you can and perhaps should cross-rotate. If you look on tirerack all available summer tires for the S7 are asymmetric, only the winter tires are unidirectional.
    Cross-pattern rotation can allow for a more even wear and reduced noise over the lifetime of the tires. I think many places just tell people front to back as it avoids the issue IF by chance they are using unidirectional tires.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 17 2017
    Redondo Beach, CA
    Quote Originally Posted by gk1 View Post
    Good point on the asymmetric tires! Just checked my S7 and the P Zeros have the OUTSIDE stamp but no directional arrow. Also checked the summer "max performance" tires on my other car and they have the directional arrow and no OUTSIDE stamp.
    Take away is best to check what kind of tires you have if you don't trust your shop to do it right :)
    Jan 10 2017
    CA
    I called michelin (I have ps4s tires). They didn't say much in terms of a recommendation. Just that as long as the tires do not say "unidirectional" feel free to cross rotate or just go front to rear. So pretty much up to the user. I'm going to cross-rotate as that makes sense to me trying to achieve an even wear pattern on all 4 tires...
